loading
Step 7: Final part.
How to get it going:
FILL IT WITH ALCOHOL JUST BELOW THE TWO HOLES
COVER THE TOP OF PEG WITH SOMETHING LIKE TIN FOIL (:DO LIKE FIVE LAYERS BECAUSE THE FIRE WILL END UP BURNING A HOLE IN IT:)
SPRAY A LITTLE AXE INTO THE HOLE ON THE SIDE OPPOSITE OF HOLE WITH AIR INPUT.
LITE THE HOLE AND IT SHOULD IGNITE THE ALCOHOL .
WHILE LIGHTING IT ALLOW A LITTLE AIR TO GET IN BECAUSE FIRE NEEDS OXYGEN TO STAY LIT.
LET IT HEAT UP FOR ABOUT A MINUTE.
AFTER THE MINUTE YOU CAN ADD MORE AIR TO GET BETTER FLAME.
IF YOU ARE USING THE FAN U MAY NEED TO GET A CERTAIN SWITCH TO CONTROL THE FAN SPEED AND AIR GOING IN.
ON THE COMPRESSOR JUST USE A VALVE TO CONTROL THE AMOUNT OF AIR OUTPUT....
no pic no trust.
no pic of it Working!!
looks like an amazing project but please make more clear instructions! i cant understandd any of it rly<br /> <br /> look at other instructables to help guide u into makinga easy to understand instructable<br />
ya sorry about that. This is my first instructable and im only thirteen...<br />
&nbsp;its fine :)
About This Instructable
4,821views
8favorites
License:
More by nikdrtbkr:rubbing alcohol jet
Add instructable to:
