3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
rubix cube belt
rubix cube belt
  • last photo ←
here it is the rubix cube belt! the only one of its kind. (as far as i know)
here's my story. regular day dieing of bored and some how I ended going through my closet and I find my old rubix cube. I start playing with it and disassembling the cube. after I reassemble it I'm bored once again an them it hits me. I should make something and needing a belt I start on the first rubix cube belt.
what your going to need is:
 rubix cube
 leather belt w/removable buckle
 dremel or dremel equivalent (corded preferred)
 dremel bit that can cut a strait line
 1/2'' screw w/point like the one in the pic
 screwdriver that matches screw
 power drill
 2'' nail
 drill bit that matches nail
REMEMBER TO SOLVE THE CUBE BEFORE CUTTING!
Step 1Prep for the incision doctor
prep for the incision doctor
take anything that will mark on plastic.then use the belt to mark the edges. after this is done extend the line to the other side making the line connect at the edge. then connect the the two line together making a rectangle and dont worry if your line are a little wonky its just a guide line to cut on.
2 comments
Jan 23, 2011. 2:08 PMvenom1539 says:
You killed the poor defenceless cube
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:monkeyman580
