Knex Assault Kit -scar 11.01 Knex -assault Knife
18,604
67
394
Published
Introduction: Knex Assault Kit -scar 11.01 Knex -assault Knife
here is a nice bottom loading magazined gun its for every one for Christmas.
It shoots around 35-45ft. and has hi power... Enough to break open a battery cover on the screaming serpent sound module.
don't forget to rate.
comment if you like it.
cool link
Step 1: Gather These Parts (part List)
this step is to see if you have enough parts so enjoy pineapplebob thegreat made the part list.
Rods
5 gray rods
3 yellow rods
48 blue rods
80 - 110 white rods
140 - 160 green rods
Connectors
8 white connectors
98 blue connectors
7 green connectors
107 yellow connectors
8 red connectors
6 tan clips
30 y connectors
3 ball sockets
20 gray one-slot connectors
8 gray two-slot connectors
114 orange connectors
1 hinge
3 cut in half orange connectors
6 ball joints
10-20 blue spacers
5-15 silver spacers
Totaling: 775
I hope this helps
Step 2: Build the Front Barrel
1.build this pretty simple
2.and this is too
3.hope fully you wern't expecting any thing.:P' " '
4.big part
5.put on all the extras.
6.a new part
7.attach both parts where the spacers are
8.more connections
9.get the part you built that looks like this...
10.and put it on here
11.cont.
12.get this part too
13.put it on here
14.get part
15.slide it into the hole on the front.
Step 3: The Foregrip
1.build these two things there are 13 of each connectors on each rod
2.add yellow connectors on like this
3.connect the other part on as shone in the picture
4.slide some gray rods through the finished product
5.and attach it at the front notice how it hooks on the y connectors are fliped
6.and in the back its just normal.
you might think it wouldn't hold on strong but it dose
Step 4: On to the Barrel/mag
1.ok this is the mane barrel. sorta like on the morrettie
2.different view note the ball joints and sockets coming off are for the trigger.
3.build all these they are for the mag
4.attach one of the parts
5.attach the other
6.get both parts that where just built and...
7.PUT THEM TOGETHER
end step 4!
Step 5: The Body!
this step will show you how to make the body of the gun... bet you new that.
1.build these two little parts
2.build this bigger part
3.build this other big part notice all the blue rods with connectors coming of of them and stuff.
4.pot the parts from the first picture on
5.cont good view to see the scopes top
6.put the other layer on.
end of step 5.
Step 6: Put in the Barrel and Mag Thingy
1.get it positioned
2.more positioning help
3.keep following snap it in place follow my connection point boxes
4.keep following
5.keep folowin
Step 7: The BUTT Lol
1.build this. haven't you built this 2 times it sure seams like it lol
2.ooooo the BUTT lol 1st part
3.the but 2nd part
4.slap them together the...current time is 2:00 A.M. so excuse me if i say stupid things that dont make any sense.
5.the BUTT is in is full but not full form
6.build this easy
7.this is the piece you just built and this is the bottom gray on the bottom
8.this is the piece you just built and its a top view of how it goes on
9.same as pic 8 just a little easier to see I think.
10.oops forgot to tell you to add a red rod there.
aurgg pictures are uploading and I want to go to bed its 2:18 A.M. }:(
11.ad blue rods wherever indicated. still sleepy.
I AM SO TIERED THERE ARE STILL THREE MORE PICTURES UPLOADING I DON'T THINK I WILL EVEN BE DONE AFTER THAT... OH I AMMMMMMM
12.build these two parts
13.connect them here
14.done!
end of step 7
Step 8: The Handle ,trigger ,and Trigger Guard
1.this is the part you will be building!
2.build these little parts
3.different view of the big piece.
4.ad those two parts on to it.
5.build these
6.these too
7.add all of them
8.the trigger house very simple
9. blurry picture but thats how you attach the trigger house.
10.trigger guard!
11.attached trigger guard
Step 9: The Ram/firing Pin
do this step after the gun is complete.
simple simple simple.
1.build the ram seriously this is the hardest part of the gun.... hopefully you didn't believe me
2.insert the firing pin/ram
3.put on some rubber bands
Step 10: The Clip
the second most simple part of the gun. I think.
1.build and gather
2.keep building
3.keep building
4.keep building
5.keep building
6.
7.put the last layer on.
8.ad th first two tan clips
9.ad the two tan clips
10.this is the pusher it dosn't need a stick on the bottom because of the awesome mag on this thing.
just loop the rubber bands through the blue connectors slot and put it on one of the blue rods sicking out of the side.
your done!
Step 11: Connection
this is a cool picture so I added it in.the current time is 2:32 A.M.
Step 12: Atach and Detach the Clip.
1.position th clip under the gun like this
2.get it on all four ball joint connectors
3.to take the clip of pull on a 45* angle downward away from you
4.and its detached.
Step 13: Intro for the Assault Knife
A blade of steel... not steel knex
heres what it looks like
stats:
has a throwing ability
it also has the looks... sorta
it can pull hair HARD. don't do it to anyone/thing ,but your self.
part list for knife
rods
green:11
white:12
connectors
dark gray:2
red:1
green:2
yellow:4
blue:2
orange:4
Step 14: Build the Whole Thing
1.build!!!
2.build more notice the white rods coming out of it
3.add pic ones parts on to pic twos part
4.ad the rest of pic ones parts on
5.other side view
6 what your done.. already?.. that was quick. lol
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    394 Comments
    I like this .... so Im putting some time into turning this into a bolt-action rifle :D
    is there a way to build a clip without the black hand?plz post if possible
    I AM VERY FAT AFTER MAKING HIM. IT WORKS VERY GOOD:)
    Chipotle Was In The Top Ten Most Surprisingly Healthy Foods, Plus I Get The Hottest Sauce Every Time I Go :D
    well yeha it's al organic there's vegies and and healthy meats there's really nothing in there that's bad to eat. if you can get a bun from mc donalds without anything at all on it. A dog wont even eat it.
    awesome job 5*, super realistic and def. the best replica around
     Dude, one of the best replicas/ mag fed knex guns i have ever seen. Unbelievable job. Faved and 5 stared. Dam this is nice.
    yeah this is one of the few guns I've had 2 at a time it was so good.
    If I ever re built it I'd put a zkar system in it..
    You can't put a zkar system it it...it doen't have a green rod square construction like most guns, this has a white rod square construction. The spacing is all different.
    can you make this with 4 Y connectors??
