Segmented Thigh Armor (in Style of Cloud Strife in Kingdom Hearts)
7,161
106
Posted
Introduction: Segmented Thigh Armor (in Style of Cloud Strife in Kingdom Hearts)
things you will need:
"tin snips" or metal shears
dremel
sharpie
drill
paper
scizors
sheet metal (i used 24 gauge)
a belt
6 nuts, bolts, and washers
tape
Step 1: Create Templates
tape two sheets of papre together and draw the outline for all three pieces. to get good symetry fold paper in half and draw half then cut along outline
Step 2: Cutting
trace template in sheet metal and cut out along outline using tin snips
then use dremel with sanding attachment to de-burr the edges... trust me the little shreds cut skin very well
Step 3: Almost Done
bend pieces over thigh untill semi-circular
drill holes in all pieces where bolts go
NOTE: inside bolt holes are oval or oblong to allow articulation(movement) outside hole are round
drill holes in belt to attach your armor
Step 4: Assembly
now its time to bolt everything together
Step 5: Be a Badass
if there are any questions, ASK. ill be happy to answer ASAP. this ible was started halway through the process of creation. exact measurements can be requested
i made this for my costume for sandiego comic-con 2011 (wich, at this point is 6 days from now)
this is my 1st ible so comments are appreciated
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
2 Comments
Is amazing, to be sure, but if memory serves they should flute out a little bit at the bottom of each segment. Still an amazing piece tho XD
thanks! i wanted to put more work into it, but due to workin and such i ran out of time
have to give thanks to my artist friend for sketching the stencils from a pic
