Self Lighting Fire Starters
24,529
839
36
Posted
Introduction: Self Lighting Fire Starters
Outdoor Survival Contest
Runner Up in the
Here's an idea that I've found helpful whenever I go camping. Self lighting fire starters aren't new and have been around for a while, except I put a slight twist on it instead of using strike anywhere matches I'm using storm matches. Storm matches, if you're unfamiliar with them the're basically matches that will burn in any condition, they are matches on steroids if that gives you an idea. Well here it is, I hope you enjoy.
Step 1:
You will need the following:
  • Storm matches¬†
  • Hot, melted candle wax
  • Scissors
  • Paper towels
Step 2:
Start by cutting the paper towel into strips.
Step 3:
If the strips are too big then trim them to be slightly shorter than the match.
Step 4:
After your piece is cut, wrap it around your match and dip it in the melted candle wax.
Step 5:
After you pull it out, let it dry for a few seconds, once it's dry then it's ready to use. All you do to light it is strike it like a regular match then place it under some dry sticks and start your fire. It will burn for about a minute and will burn in the rain, wind, and cold to get your fire burning.
if you want to see many more things like this then be sure to follow me. If you made this yourself then I want to see it, leave a photo in the comments below. For all my followers I say thank you for the support. Don't forget to vote for me in outdoor survival contest.
  • Love this idea. Than...-theskategeeks
    theskategeeks made it!
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
34 Comments
Has anyone tried this but instead of toilet paper used cotton balls with vaseline?
Thanks for sharing. Must use this idea one day.
I had to combine 2 Instructables!!!!
Here it is
whats the blackish parcel on the bottom? charcloth?
In my endeavor I have used lint, I collect from our Laundry mat.
10 lbs block parraffin ( A BIG PAIN TO CHOP WITH A CAST ON)
And oooooopdlesbof matches
no egg cartons due to possible Salmonella contamination
WHO KNEW
