If you want more details on why the basics are set up a certain way, there are plenty of great instructables both here and all over the web, so I won't reinvent the wheel in this one, but this should be everything you need to get up & running.
Not starting with a pre-built plastic container as the main housing means some extra steps, time, and care, but for me the final product is worth it.
Remove these ads by
Signing UpStep 1Gather materials
- (3) found dresser drawers
***Before you get the other materials, take careful measurements and know what you're working with. The length and width of any drawer determines the size of the screen/basket(s) you'll need; the height of the bottom drawer determines the height of the ABS pipes, etc.
- 1 piece of 2" diameter PVC pipe (length should be the total height of all drawers stacked, or slightly longer)
- 3 pieces of 3" diameter ABS pipe (about 1/3 of the total height)
- 2 plastic baskets (or something stiff and porous enough to serve as a nontoxic, waterproof, weight-bearing screen)
- outdoor stain & sealant combo wood finish, or paint for waterproofing
- brush
- wood glue
- drill
- utility knife
- wire, string, or cable ties
- landscape tarp, opaque plastic bag, or river rocks
- potting mix
- fertilizer
- plant(s) or seed(s)
Optional:
- painter's tape (to prevent bleeding)
- tarp or old newspapers (for easy cleanup)
- gloves
- river stones or rocks (as one more layer between the soil & water reservoir, and as a topsoil cover)
- Leatherman (it just feels good)
*from the hardware store, .99 store, nursery, your local curb, or the Craigslist free section
One thing I learned elsewhere that would work here: Instead of needing the plastic mesh and pipes down in the bottom, you can save time and work, and recycle some plastic drink bottles. Just drill small holes all over three sides of each bottle, cut a slit (about 1 by 3 inches) in the bottom, keep the original lid ON. Make as many of these as you need to lay into the bottom of your planter. These serve to "self-water" through your main pipe to the soil's top just as well as the mesh-and-cut-pipes do. I tried this with one large fig tree and it worked splendidly.
You can also use different width eaves-trough, it comes in 4 - 10" widths.
It's fairly cheap to do, and would let you keep most of that moisture off the wood. Would also let you customize to almost any size/shape of wood container.
I'm planning to try this using a long window box style planter on my front deck - it gets lots of sun and is quite dry so having the self watering container will be key for growing the planned tomatoes and cucumbers.
I'm going to add a link to this over on our forum. Our website is centered on homesteading type subjects. Gardening and alternative ideas is definitely a large part of that mindset.
Great job!
http://www.theruralindependent.com
