3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
self-watering planter from found dresser drawers
Step 5Drill holes & cut screen
drill holes & cut screen
Drill holes in all ABS pipes to allow the soil to pull water up from the reservoir without spilling into it.
I also used holes at the bottom of the fill tube instead of cutting it at an angle, only because the drill was out and it serves the same purpose of allowing water to flow into the reservoir.
I needed 2 baskets to fill in the extra length of the drawer, so I did the same (see photos) to both, cut down the edge, and laid one on top of the other. Yours may be a different length or from a different material, as long as it serves as a screen and ends up fitting snugly against all sides.
Use one of the ABS pipes to mark a spot for the overflow hole, then drill. This is to allow excess water to flow out, so your roots will never be water-logged.
2 comments
Apr 25, 2010. 8:47 AMEmKay73 says:
Could you have used galvanized "hardware cloth"? Its a fencing item like chicken wire that comes in a 1/4" or 1/2" grid widths.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:chandra.nalaani(portfolio)
Front End Web Designer/ Developer, Multimedia Artist, Maker
