Sell Transparent LED Strip Display With Ultra Slim Body and Sharp Brightness Contact: Kallen@huasun-tech.com
Published
Introduction: Sell Transparent LED Strip Display With Ultra Slim Body and Sharp Brightness Contact: Kallen@huasun-tech.com
About: Hi, this is Kallen from Huasun, we are flexible LED curtain manufacturer. Flexible LED curtain which is light , thin, portable, easy. Making the stage decoration easier. With Professional Factory, we can mak...
Transparent flexible LED display is composed of flexible rubber strips in which the high illumination SMD LED is embedded, the controller and power is connected in the aluminum box which is hung on the top of the screen, so that it can be rolled and folded freely like a paper, it is lightest LED display with high rate transparent, high rate waterproof.
1) Ultra slim body like a paper, and 1KG/sq.m, very light
Easy to install, especially suitable for fast installation.
Rolled and packed by Flightcase, save transportation fee
Totally 90% project cost saving, one-time invest, long term benefit.
Soft and flexible, it can be folded, bended, curved and rolled freely like a newspaper, which is suitable for any irregular place like arch, cylinder, rectangle. 2. Ultra-light weight, slim body, which is suitable for the place that requires the weight strictly, and for convenient transportation.3. Easy maintenance, every parts can be replaced without needing professional people.4. Easy and fast installation, demolition, there are only signal cable and power cable, less cable which are suitable for rental and instant project.5. Free expansion, there is not any limitation to connect many small panels together vertically and horizontally and vertically to make a display as larger as you want.6. Irregular shape is available, like triangle, round, ellipse, …7. Custom size are available, besides the standard panel size, we can make nearly any other dimension8. Transparent and wind-proof, so lighting and wind can go through the body of the screen; if transparency is unnecessary, so the black background clothing is available.9. Alternative controlling system: Video synchronous and off-line controller is alternative, support third party video display software.10. Waterproof: the ingress protection level can reach to IP 65, it can be merged into water and works perfectly.11. High refresh rate, it can achieve 68 billion colors and 5000 - 23000 HZ refresh rate, so there is not any strobe and water ripple effect through the video VCR, it is very important for stage display applicatio12. High brightness: the highest brightness can reach to 10000 nits, it can be used under the sun shine environment.
13. Beautiful and safe package:move and transport easily with low cost.
Website: www.huasun-tech.com
Email: kallen@huasun-tech.com
MSN: huasun-tech@hotmail.com
Skype: kallen1987
Mobile: 008615801631187
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
