3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
sequin relief t-shirt (with dinosaurs!)
Step 4Trace outline
trace outline
Turn your donor fabric inside out.
Locate a good patch of fabric on your donor cloth. Position and rotate your paper image cutouts, then outline your image with a marker. I chose a coloured marker, depending on your fabric your marker colour could bleed through. The effect is awesome.
Don't worry if you mess up the outline, you can always choose another colour marker and try again in the same spot or a little offset. This part will be sewn inside and will be unseen.
When you are satisfied with your trace carefully cut out your outline.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
761
Author:mikeasaurus(michaelsaurus.com)
I'm the Play Editor here at Instructables! I like mixing old ideas with new and reusing things not for their intended purpose; the results are sometimes messy but always fun. I also write the thrift-...
more »
