3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
shaved door handles ...... the cheap way
every one in the car field knows and has seen a vehicle mod called ""shaved" door handles" usually to install this nifty item you need to find a customs shop or buy a expensive kit ... either way for the result you are looking at about 2-3 thousand dollars but my approach was less bar far expensive around 45 dollar may be less because i wanted to go fancy ed to find a customs shop or buy a expensive kit ... either way for the result you are looking at about 2-3 thousand dollars but my approach was less bar far expensive around 45 dollar may be less because i wanted to go fancy
Step 1The items you will need
the main item needed is door lock actuators .. off older vehicles (the ones off older vehicles have a lot more power to pull larger locks)
you can usually find door lock actuators at your local bone yard for about 3-5 bucks for a pair ..
so to recap you need
2 door lock actuators
1 clothing hanger (the wire kind)
assorted wire
and a few small scraps of sheet metal
2 water proof momentary freezer door switches marked ""off"" position (finding ones marked off is very important other wise once switch is installed it will be always conducting 12V and your locks wont work )
1 3 way momentary switch
electrical splicing caps
TOOL
the tools you will need
screw driver
drill (and bits)
metal punch
ruler (I say ruler because it is simpler to use in side the door than tape)
and wire crimpers
43 comments
1-40 of 43next »
Apr 18, 2012. 7:36 AMcurious youth says:
can you do an ible on how to do this with locks still in place ? otherwise this is great !
Nov 9, 2010. 9:01 PMdaniel 96 says:
wat i didnt understand is wats is da 3way momentary switch for? an wat doo i connect it too? please write back i need ur help man. thanks!
Feb 26, 2012. 7:16 AMabstracted says:
open at rest, momentarilly closed in the other two switch positions....drivers door (((POP))) passenger door ((POP))
Dec 28, 2010. 10:28 PMrianocerous says:
Cant say for sure, but I'd imagine it's so the driver can pop either door from the inside?
Apr 30, 2011. 8:18 PMzwooten says:
So do you use a key to open the door? I don't think you mentioned that at all...
Feb 26, 2012. 7:14 AMabstracted says:
keyholes usually shaved too...no door handles no locks needed
Oct 16, 2011. 9:04 PMDiabloscope says:
nice , I think i have done this over 600 times in the last ten years on many different makes and models of cars trucks and everyone of them was fun some were hard , but was always a learning experience . its also nice when you have a car or truck that has electric locks already YOU CAN USE THE EXISTING LOCKS TO POWER THE SOLENOID OR LOCK MOTOR , USING LOCK FOR THE DRIVERS DOOR AND UNLOCK FOR THE PASS . Oh and about using a Wire Hanger , is not that good the hanger is too thin and will FAIL under pressure !!! and like i did Have a Pissed off Customer that has paid 300.00 to have this done and have his car/ truck towed to the shop to fix , since you are going to the Junk yard Pillage some of the door lock and door opener rods from other cars , or if you are really clever like like me LOL you can get some stranded wire cable from Home Depot or Lowes coated or not and rig up a pivot and pulley set up ! Good Luck and Have Fun !!!
Feb 26, 2012. 7:12 AMabstracted says:
motor bike spokes, already end-bent with a head on it to hook to actuator, and super strong......whoz da clever one now? LOL
Feb 26, 2012. 7:09 AMabstracted says:
being a custom car audio installer extrordinaire (laughs at self) i warned many a persons, that ......"YOU NEED AN EMERGENCY BACKUP MECHANICAL REALEAS DUMBA**!!!!" when your battery goes dead...theres no other way in, even to pop the hood. I`ve recomended, bicycle cable hiden in the inner front fender, a hiden external hood release (useless if its remote fob failure, or keyless entry module failure) so battery can be boosted. or some sorta exterior power port hookup...you get the idea. mech-over-ride still best.
Feb 19, 2012. 8:20 AMbg_askins says:
as far as the bondo issue goes. i had a buddy fill his old handle holes with liquid nails then smooth it out with a thin layer of bondo and that was years ago with no cracking. i know its the wrong way but some people either can't weld or can't afford to have it done for them. he finished his truck with rustoleum. heres a link on how to do that.
http://www.instructables.com/id/Paint-Your-Car-With-Rustoleum/
Feb 6, 2012. 8:54 PMgreggspen says:
But why would I shave my door handles? They aren't that hairy!
Mar 13, 2010. 10:05 PMYerboogieman says:
Hey! I have a Ford Ranger.
Feb 6, 2010. 9:34 PMnocturnechanson says:
 should have welded those holes the bondo will over time shrink the crack due to vibration. for heavy applications you are better of laying a base of Dura glass the using the bondo for a smooth finish.
Nov 19, 2009. 3:59 PMSTEELBREEZE says:
As a professional custom body shop owner, I had to leave my comment. This is a good instructional for those trying to cut corners and save some cash. When I shave door handles, I always hook the trigger to an auxiliary outlet in an existing alarm system so the remote can be used to open the doors. The lil "poppers" that help open the door are just enough to get them to the point that you simply open the door by holding the edge of the door at the door jamb. As far as the hole in the door. The ONLY way to have it last is to weld a piece of sheet metal that conforms to the original shape in place. Grind the welds smooth and a light coat of body filler will finish the job. Sometimes, as in this case, to do it right is easier and faster than to do it wrong. (filling it with bondo). But all in all, this instructional will help a lotta people get the job done. if you're not good with the metalwork part, you can do everything else and then when you're done, take it to a local body shop and have them do the final touches for you. it will still save you a lotta cash as a whole. I also have used trunk actuators do make the doors open. This works for most modern cars with easily opening doors. Older cars might need stronger actuators. Somewhere in the 45lbs range. Trunk actuators push about 11 lbs.
Aug 22, 2008. 8:04 PMshammallamaman says:
Why do you want to not have door handles?How do you open the door now?
Dec 11, 2008. 9:53 AMuberchoob says:
dude, read the whole instructable.... He's now got a hidden button that opens his door.... why? It's just damn cool. But if you really just need justification, It makes it so he can open the door with his foot while he's carrying groceries for the wife.
Aug 8, 2009. 8:40 PMcandle360 says:
hahahahaha, that's good justification lolz
May 17, 2009. 5:55 PM2nup350 says:
a few important points. be sure to wire the ground for the switches through the neutral safety switch so you cannot open the doors while driving. also, WELD the door locks so they CANNOT be locked(experience speaks here-i had a car lock itself after 2 years of trouble free operation, the door locks just fell down even with no rods on them) you don't need the inside door locks anyway. and one last point- please reformat this instructable to eliminate the run on sentences. i had a hard time deciphering it.
Aug 5, 2009. 1:48 PMcandle360 says:
I have a car that's standard, how would I do that? I disabled the switch that requires the clutch in while I start it, and I don't have a neutral safety switch anyway since it's standard
Aug 5, 2009. 8:46 PM2nup350 says:
then wire up a 5 pin relay so the door solenoid relays only have power when the ignition is off- on a Bosch relay you should wire to the (87a) normally closed terminal and have ignition power to hold the relay open when the engine is running
Aug 8, 2009. 8:39 PMcandle360 says:
ha, I was just kidding. I really like this instructable but I have a camaro, and it would look kinda wierd, cause it's a sports car and it's not in perfect condition where I would have shaved handles anyway
Apr 25, 2009. 8:31 PMluvit says:
cans i do this to mine house?
Mar 18, 2009. 5:41 AMhughgoh says:
does this lock also? Does the actuator go both ways? push, and pull? Thanks
Dec 29, 2008. 11:00 PMThe_Beast says:
They also sell emergency popper kits in case your battery does go dead
Jul 9, 2008. 2:30 AMRishnai says:
I have to agree with everyone else: that bondo isn't going to last. Bondo works great when applied to a stable substrate and applied no more than 1/16 of an inch thick. These meets neither of these criteria. Please let us know how long it lasts, but my money isn't on that being very long. One alternative to actually doing the proper metalworking, which is easy, but still a pain if you don't enjoy bodywork, is to take some steel and rough out the contour. Weld or braze it in, then apply bondo or lead, and sand until it matches. It's much less likely to crack or fall off that way.
Jun 18, 2008. 3:16 PMchalky says:
excellent,clear,and easy to follow.........just one Question................................................................Tell us what the orange button does lol:)
Jul 9, 2008. 2:22 AMRishnai says:
It operates the ejector seat. "Turn up here! Your turn's coming up!" "I know, shut up, I have to get into the right lane." "You're gonna miss your turn." "Shut up." "But you just missed--" click-whoosh "AAAAAAHHHHHH!"
Jun 20, 2008. 1:47 PMPlasmana says:
Umm... Make a big boom???
Jun 20, 2008. 8:12 AMxACIDITYx says:
I'd bet that this isn't the first modification he's done on his truck.
Jun 23, 2008. 8:43 PMFletcher says:
I wouldn't advise filling the empty door handle socket with body filler. Eventually, it's going to crack and likely fall inside the door, exposing the holes again. (Especially if there's nothing solid backing it.) May be fine for your summer beater but a costly mistake if you go to the expense of having the vehicle painted. Unfortunately, there's no cheap way to patch the holes. Ideally, you'd weld in a steel patch. For door handles that reside on body lines (as this vehicle's door handle appeared to) you'd either need moderately decent metalwork skills and tools, or a trip to the local scrapyard for a patch piece from a similar donor vehicle.
Jun 29, 2008. 8:59 PMFletcher says:
How do you get it to adhere to the thin-edged sheet metal socket in the door skin? I think even a JB Weld-type compound wouldn't stay attached for long, especially with such little surface area to adhere to. You could 'lap' some of the material glob along the inside of the door skin, but I still wonder how it would hold up against repeated door slammings, and general vibration the door is subject to. I do see what you're saying, and how you could get it to work, but I question the long-term quality. May not matter on a for-fun project car, but anyone who is considering an expensive paint job over this should really consider the long term viability of the fill. Example: Right now I'm working on a `68 Mustang that had some very creative bondo work done by a previous owner. The driver's side wheel lip was reformed from roughly pie-cutting a strip of steel, RIVETING it in place, and then artfully shaping the arch with filler. Years of heat and cold eventually caused the bondo mass to distinguish itself from steel, and half the quarter will now be replaced. The short response is: There are numerous ways to do a thing, but only a few right ways. As an aside, this sort of reminds me of a friend who hand made fiberglass Testerossa-style strakes on his CRX (don't ask) with scrap cardboard cores.
Jun 18, 2008. 7:03 AMPetervG says:
How do you open it then?
Jun 18, 2008. 7:58 AMnnygamer says:
Step 4 explains that. There are switches inside to trigger the electric catches and on the outside the switches are located underneath the rocker panel. You just need to tap it with your foot.
Jun 18, 2008. 10:07 AMHoopajoo says:
What if your battery is dead?
Jun 18, 2008. 10:13 AM=SMART= says:
if your battery is dead your dead because you cant get out
Jun 18, 2008. 10:31 AMgog says:
Only if the windows dont work either :)
Jun 18, 2008. 11:32 AM=SMART= says:
oh yea, diddnt think of that
Jun 20, 2008. 6:57 AMwick_ed says:
Generally, anyone who knows what they are doing leaves the inner door handles in. That way, you aren't locked in the car!? If you are worried about the car battery, just hook-up a small 9 volt battery adapter direct line to the door latch and use it for a by-pass system. Some place where the hood needn't be popped. If you have a newer car, you can buy the remote entry set for around 75 bucks off the net and not worry about buttons either.
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:arteral157
