if used as directed this project will give a non-lethal shock that's kind of fun
this project will never need to be plugged into mains voltage
i am never responsible for anything you do
i actually stumbled across this concept via painful accident
i applied power to a transformer then when i turned the power off it shocked me
i tried it ten more times and figured out what what was happening
power was being transformed and then stored in the inductance of the transformer then being released as a shock
(somebody correct me if i'm wrong or they find something smarter)
(knowledge is power)
Remove these ads by
Signing UpStep 1Matreials and tools
-knife
-standard screwdriver
-wire cutters
-soldiering iron
-grinder(optional)
materials:
-9V battery snap
-or-
-alligator clips
-ac/dc transformer
-clickey switch
-2ft light grade wire
the transformer needs to be at least 5V and 300ma. just nothing wimpy.
a 9V battery is preferred but you shouldn't use anything stronger or you could hurt yourself.
you can use the battery clip or the alligator clips, either is fine.
...so half of that is 500ish. that should make your coil explode.
try to keep the current under 500mA
most AC adaptors only draw about 300 - 1000mA
a shorted 9v will put out 1-3Amps
