Shock Machine
29,518
40
36
Published
Introduction: Shock Machine
well, its my first instructable so it may be bad if you put bad critics i wont see them but if there are questions i'll answer.
it's very cheap, like 10 bucks or less.is a shock machine, its very funny to put to max level and see the face of the other guy.
its high voltage but low current (it's like 40 v .5 Amp)
Step 1: Components
you will need:
2 LEDs
1 Variable resistor 100 K
1 Transformer for 12 V with central derivation
1 switch
1 NPN transistor TIP31C
1 Resistor 560 OHM
1 or 2 battery clip (for 4 AA batteries)
4 AA batteries
2 Copper tubes
a lot of wire
soldering iron
solder
patience
Step 2: The Circuit
well here its the circuit:
Step 3: Thats It !!!
if you want more power you can put a 9 V battery but you have to put 3 LEDs.
if you take it to school you can win a lot of $$$ money $$$!!!
    • Planter Challenge
      Planter Challenge
    • Pets Challenge
      Pets Challenge
    • Clocks Contest
      Clocks Contest
    36 Comments
    Estas bien puñetas
    I was wondering how bad this hurts on a scale of 1-10? Im trying to make sure it does less than 5 because im doing an experiment, also does it have anything to signal that its on, say a light that lights up? Contact me at mikeloredo25@gmail.com
    Hello, You did not mention the voltage of the LEDS
    when i hit the button alls that it does is lights up im not very good at schematics could send me somthinge that could help
    nothing it charges the transformer and then releases the shock once and then you reset it by turning it off
    hey man i tried hookin it up just like d electrical diagram but it only shocks u wen u turn on an turn off the power switch wat am i doin wrong
    no tengo camara pero baje esa foto, yo la hice.
    Can you e-mail a hand sketch of what it should look like or type out the instruction on how to do this. I am totally lost.
    i got one i got it at mexico for 200 pesos but i think it was at the centro and i kinda makes you money but eh idk here in new york there rare
    can i use a tip 3055 transister
    hey for the variable resistor do we use all three outputs
    only the two on the left
    Tell them that if they can handle up to level 8 they will win the jackpot , if they don't , they'll give you 5 bucks
    They used to explain that these sorts of devices were "safe" because of the limited amount of power you could get out of batteries. There have been a lot of advances in battery technology since then (that was "Before Alkalines"), and I wonder if such circuits are still safe? The 0.5A value quote is certainly NOT safe; the generally agreed upon dangerous value for current through the body is about 20mA (0.02A) (of course, that's THROUGH the body, not measured on a meter "direct to ground.")
    I personally own one of those , and the MAXIMUM OUTPUT CURRENT IS NOT HALF AMP
