short sword / dagger sheath
 by eliboom
This is a short short / dagger sheath if you have a short sword thats lying around (you probably dont) and you want to make a sheath or just want to make a lighter sheath for your short sword.
Step 1: What you need
For this sheath you will need: scisors, any colour of thread (i used black) ,a ruler, a sharpie marker, leather, a leather hole punch, a flute/ recorder case (hard or soft, soft is good) ,and a weapon OR a recorder for a cool case. P.S. if you want you can cover the whole sheath with leather.
curvy77 says: Nov 28, 2011. 6:34 PM
but sir i truly do have a (long) sword just laying around. lol. thnxs for the instructable.
KentsOkay says: Mar 19, 2007. 2:26 PM
You could just make a real leather sheath. You can make a sheath out of either oil-tanned garmet leather (cheap, easy, is only a soft covering) or a veg-tanned leather scabbard (hard to make, rigid, way more durable and cool.) Ask me if want specifics
master-of-chaos in reply to KentsOkayJun 3, 2007. 7:46 PM
well i want specifics
KentsOkay in reply to master-of-chaosJun 4, 2007. 6:22 AM
Right what do you want, a scabbard (hard) or a sheath (soft)?
master-of-chaos in reply to KentsOkayJun 4, 2007. 1:52 PM
hard
KentsOkay in reply to master-of-chaosJun 5, 2007. 9:03 AM
I'll be gone for a couple of days, I'll PM you later.
master-of-chaos in reply to KentsOkayJun 5, 2007. 8:44 AM
k
icedog515 says: Apr 25, 2007. 6:47 PM
nice weapon dude
rplatter says: Apr 25, 2007. 2:46 PM
Most sheaths I have seen have two flat boards (For lack of a better word) These are a little wider and longer than the blade. They pinch the blade between them. A slight hollowing of the space between the boards centers the blade and the outer covering will provide the restriction/compression. The edge and point of the blade never touch the outer covering.
domiboom says: Jan 25, 2007. 11:30 PM
Fine, but I liked the final design for the sheath, although I could of made it ten times better. Just kidding, =) I liked it.
eliboom (author) in reply to domiboomJan 26, 2007. 5:26 PM
ya again with my name... BE CREATIVE!!
jtobako says: Jan 26, 2007. 3:09 AM
you are going to need to make the cloth portion rigid or the tip of your sword is going to rip threw it if you don't put it in just right. you can do this with a piece of wire sewen into the seam of the cloth (so it doesn't knock against the blade) or a piece (or two) of cardboard glued or sewen outside the cloth.
flyingdom says: Jan 25, 2007. 11:13 PM
OMG NICE SHEATH
eliboom (author) in reply to flyingdomJan 25, 2007. 11:17 PM
thanks but CHANGE YOUR NAME... or should i say my name... '-'
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
