Shower Stall Remove and Replace 2 of 7
Published
Introduction: Shower Stall Remove and Replace 2 of 7
About: http://www.coolplumbingvideos.com These " How to" Plumbing videos are a must. Even if you feel you know everything there is to know about plumbing repairs, there is something in these videos for you. Just ...
Remove old shower stall and install new shower stall. Cut water to house off or if there are cut off behind the tub cut it off there. Carefully remove the old tub and shower valve. Remove handle, and esuction plate. Cut old valve out from the back side wall Clean work area and begin prepping the new tub and shower valve for installation. Begin install putting the new tub and shower in place and solder together , then come back to the tub side of the faucet in install the tub a shower trim.
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    Great instruction so far,except you didn't show the hardest part of this segment of the operation-removing the old drain!
