loading
Step 3: Assemble and Start Plating!
step1 - connect the copper electrode to the positive side of the battery, and dip it in the copper sulphate sollution(copper sulphate crystals dissolved in water).
step2 - connect the carbon electrode to the negetive end of the battery and dip it in the sollution too.
step3 - drop the metal object you want to plate into the sollution.
edit: as pointed out by @HeWantsRevenge in the comments-  for a nice even coating, it might be a good idea to suspend the object.. with thread or wire.
thats it.
Do note that not every battery have a carbon rod inside. Only zinc-carbon battery do. They are usually labelled as "Heavy Duty" even though they are terrible batteries.
<p>thanks!<br>your right.</p><p>thought i'd replied to you already! </p>
<p>Agreed, couldn't the carbon rod (graphite) inside a pencil work just as well, or would the clay mess with the reaction?</p>
<p>heh, graphite pencil cores do work.. but a lot slower.. could be the clay, but i think its the thinner diameter.. the battery core results in more surface area exposed to the solution</p>
<p>how much copper sulphate should be used?</p>
i used 4-5 table spoons for 400ml of water
<p>I'm using copper sulfate to plate with.I'm following all the prosedures for prepping the metal to be plated and for some reason the copper will not stick.Please help me.</p>
Talk to a chemistry teacher!!<br><br>If that's not possible.. <br><br>Try distilled water.. Sometimes hard water makes the process slower<br><br>see if bubbles are generated at the electrodes... If not then your batteries are too weak... Switch polarity..see what that does(probably a useless exercise)<br><br>I can't think of any other advice to give you on this
I think you'd have better success if you attached the key to the negative electrode-<a href="http://en.wikipedia.org/wiki/Electroplating" rel="nofollow"> this Wikipedia article</a> explains why. You can actually do without the carbon electrode completely if you just attach the negative electrode wire straight to the key or metal object. &nbsp;I suspect that your experiment was doing a simple substitution reaction: iron in the key reacts with copper sulphate in solution to give iron sulphate and copper metal.&nbsp;<br> <br> Still, kudos for going above the basic level your school expected and actually finding something out for yourselves. &nbsp;I did a similar thing in my first year- we were meant to measure the amount of carbon dioxide given off by yeast by counting the bubbles, but my friend and I figured this would be more accurate and less boring if we captured the gas in an inverted measuring cylinder and found the actual volume. &nbsp;<br> <br> The science teachers listed possible flaws with the experiment, and we gave solutions to them until they just let us do it our way to shut us up :)
<p>you talk too much.</p><p><br>it's too common.</p>
yea...i think u goto hang whatever u wanted plated to the negative so the copper is attracted the object. at the very least...hang the said object for a good even coat
hmm, excellent idea actually, thanks :)
I know this is a little late in the game but it's easier to open a battery with a tubing cutter theones used for cutting copper tubing you can cut the top and bottom off and peel the oiutside skin off real easily no hammer required !
good that helps.. will add it to the instructions.<br>thanks
your suspection is totaly right... it is all about the standard potential of the elements/ions used ( http://en.wikipedia.org/wiki/Standard_electrode_potential_%28data_page%29 ) the reaction works without electrodes and there is one similar reaction you really should try out. with this you reaction you can make 'gold' (well it's brass but looks similar) just throw a piece of zinc into the copper sulfate solution. (learned that at school when i was 14 i think)
thanks for the feedback, truely constructive. will try it without the carbon rod and see how it goes.
<p>You should have the key attached to the negative electrode, not sitting in the middle. You don't need the carbon electrode, just the metal thing to be plated attached to the negative wire. I recommend alligator clips to attach to the electrodes. The copper solution can be made using your copper electrode and vinegar or lemon juice as your electrolyte liquid - after attaching the batteries, the copper ions will be pulled off the electrode and into solution. when there are enough of them, they will start to plate the key.</p><p>You shouldn't put large amounts of copper solutions down the drain - it needs proper chemical disposal. Check with your local university's Environmental Health &amp; Safety dept for how to do this properly. Or you can throw in a wad of steel wool to precipitate the copper back as a solid.</p><p>Here's one I made using sharpie to stop it plating in places.</p>
<p>you talk too much.<br><br>it's too common.</p>
<p>wow..<br>you the best.<br>i like it.</p>
you spelt &quot;earring&quot; wrong. you spelt it with only one &quot;R&quot;. Lol sorry i had to point that out.
And you spelled spelled wrong!!! Nitpicker....
<p>per merriam webster online dictionary:</p><h2>Definition of <em>SPELT</em></h2><div> <em>chiefly British past and past participle of</em> <a href="http://www.merriam-webster.com/dictionary/spell" rel="nofollow">spell</a></div>
good spotting :) will change it!
<p>Will the lead from a graphite pencil work as a carbon electrode?</p>
<p>Lead from pencil is not as pure as battery carbon rod :)</p>
<p>it might, but will work very slowly.</p><p>i found that using a fatter electrode greatly speeds up the process.. hence instead of AA i tried a fat torch battery(&quot;C&quot; cell) and it suddenly started happening faster. the larger the electrode the better</p>
thanks @matroska , have added it to the instructable
Is this Ionic transfer?
yes i believe it is.
you could use it in your Antique Crank Phone Hack instructable you know :) to create a steampunk look for some of the metal parts
That was more of ah contract job and the lady wanted it as original as possible considering what was being done to it. <br> <br>I use baking soda in boiling water and an aluminum baking pan to remove tarnish from silverware. Ionic Transfer. All is needed after that is ah light polishing to make 'em beautiful. Takes all the real time work out of the deal.
good to know!
does vinegar work?
no clue, never tried
also well i want to say to every one ho read this<br><br><br> DO NOT ATEMPT TO OPEN A BATTERY YOU WILL SQUERT ASID IN YOUR <br> EYE<br><br>sorry but this is not safe<br><br>p.s. use penneys insted they work just as well(with vinegar)
squirting?? otherwise YEP .!!!
yup i should have mentioned that earlier.. will add the warning now. <br>.. though have never seen a battery &quot;squirt&quot; anything in all the times i've dismantelled them.. still i guess it could happen. warning duly noted
well if your yousing a hammer to open it...
..How does this work with the key just siting in the liquid????
as the electrons transfer from the copper to the carbon electrode, it also latches on to any conductive metals in the liquid.
would probably work faster if its connected to the carbon rod.. but works fine this way too.
yes-thats the way its done
The sort of battery from which you'd get a carbon rod is the old style dry cell, not one of the newer alkaline batteries. The black powder surrounding the rod is manganese dioxide, a useful chemical but it should be handled with caution. It's also messy as all get out so do it outside.<br><br>These batteries (actually, they are cells... Batteries are made of several cells in a series) shouldn't contain any liquids to &quot;squirt&quot; into your eyes. Nevertheless, anyone working with chemicals without proper eye protection is asking for trouble.
thanks for that highly informative comment.<br>i appreciate it.
About This Instructable
74,560views
158favorites
License:
Bio: a Designer and Digital illustrator, working full time as a web and game designer. Work mostly on fun online media like Web games and rich ... More »
More by chaitanyak:Assigning Multiple Drives to Steam on Linux Model animals and bugs in your browser How to 3D Sculpt in your Web Browser..
Add instructable to:
