Simple Arduino Virtual Keypad
Published
Introduction: Simple Arduino Virtual Keypad
Hello i just  created this simple keypad to unlock doors or do some other stuff
requirements:
computer(any os)
arduino
optional for building relay switch
relay 5v
diode 1n4007
resistor 270 ohm
optocoupler
external supply
Step 1: Bulding Relay Switch
Step 2: Upload Code to Arduino
char inData[20];
char inChar=-1;
byte index = 0;
void setup(){
  Serial.begin(9600);
  pinMode(12, OUTPUT);
char Comp(char* This){
  while(Serial.available() > 0)
    if(index < 19)
      inChar = Serial.read();
      inData[index] = inChar;
      index++;
      inData[index] = '\0';
  if(strcmp(inData,This)  == 0){
    for(int i=0;i<19;i++){
      inData[i]=0;
    index=0;
    return(0);
  else{
    return(1);
void loop()
  if(Comp("6729")==0){
    Serial.write("GRANTED");
    digitalWrite(12,HIGH);
    delay(50000);
    digitalWrite(12, LOW);
Step 3: Changing Password
if you want more than 19 digits just change "char inData[20];"to number you need and all 19 to your number-1
Step 4: Run Arduino Virtual Keypad
now all you need to do is unpack ziped files and open (for windows)application.windows32 and run sketch_130540a.exe
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    2 Comments
    Thanks for the tutorial! I will definitely build this soon. One question, could I use a arduino 4*4 keypad instead of the pc and do you have any idea how I could make the ABCD buttons each turn on a different relay?
    Thanks again
    Thanks! This really looks fun;) next chance I get I'm going to check this out. Thank you again
