Simple Lego Phone Stand
Published
Introduction: Simple Lego Phone Stand
there are many different phone stands made from lego, the one better than the other.
some are easy and simple but not sturdy
some are complex and very sturdy
some require special parts.
i made this tuturial for a easy simple, stand that doesn't require many parts
Step 1: Asemble
for this you need
9X 15 hole lego bricks
5-9X technic blocks
some flat plates.
2 1x1 flat block
lots of black technic conectors (2/3 blocks)
some joint conectors (gray ones)
its easy to asemble and very sturdy.
Step 2: Use It As a Stand
put the gray joint-connectors in the positon of how high you want your phone.
then its easy to use.
Step 3:
    • Stick It! Contest
      Stick It! Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    4 Comments
    its connected trough 2 1x1 flat lego blocks
    the lego is stacked trough normal and then conencted trough the 9 hole technical parts
    its one of the better model stands and can be modefied by using the 1x? slabs on a alternate place so the curve is different.
    its also more durable and portable, due only being 2x8x15cm max in size
