Simple No Pump Water Rocket
Introduction: Simple No Pump Water Rocket
this is a fairly simple water rocket using only the pressure from your tap ,suprisingly there is alot of force from the tap and this rocket will put it to use in a simple way ,at a low cost  . it can reach heights of 10m-20m    30ft-60ft
Step 1: Materials
you will need:
pvc cement
a male director that screws into a gardina nozzle width 25mm( 1 inch).
about 4cm (2inches) of 15mm pipe (0.6 inches)
a male director that screws into a gardina nozzle width 25mm(1 inch)
Gardina nozzle
cable ties
tools :
Step 2:
screw the male director into the gardina nozzle
Step 3:
just push the pipe onto the male director (it should be tight)
Step 4:
get your threaded pipe and screw it into the  plug that fits into the bottle , length dosent matter that much
2 examples shown
Step 5:
now brush on the cement on the inside of the threaded pipe and the out side of the 15mm pipe
Step 6: Your Done
now just let the cement dry, mount it onto a post , fit a bottle and hit the water
Step 7: For Extra Height
the pressure can be improved by covering half of the plug that fits in to the bottle with electrical tape or another thin tape that stretches
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    My outdoor tap supplies about 100-105psi so I use that to fill a old air compressor tank to that pressure and then use it as a water gun! :)
    Never do that. It will rust out and explode. By the way, I have the same water pressure.
    sounds bloody awesome, would not want a 100 psi pipe blowing underneath my house though .
