Remove these ads by
Signing UpStep 1: Gather your materials
-1 soda bottle(with cap)
-a used toilet paper roll
-a knife
-safety goggles(not shown)
-rubbing alcohol
-grill lighter(not shown)
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Long ago, I did something like this with a plastic milk bottle and propane. Since I didn't use a nozzle, it didn't go very far at all. However, I'm not sure they're strong enough that they wouldn't burst if you used a nozzle. So if you try it, figure out how to light it from a ways back. Certain bottles will make spectacular whistling noises if you do this kind of thing, which is how I got the blister I mentioned before.
You might find the mix easier to get consistent if you use an eyedropper to measure the alcohol you're putting in.
Regular water rockets can go much higher than this, though they're a bit more work. They're also a bit hazardous, or at least they can be, which is perhaps less obvious because of the lack of fire.
dinosuars rock
So be careful if you use it.
do i fill the cap or bottle? i really want to make this, so if you can clear this up ill make it =]
