simplified firefly jar by Dannos
This is my first instructable so be kind please. Please also keep in mind I'm not an electronics expert. I know just enough to not know what I'm doing.
I was inspired by photozz Fireflies - Analog version. I had two 555 timers but didn't have the cd4026b IC. Instead what I had was a sn7447an IC. Even with the help of photozz I still couldn't get it to work. So I started looking for a different way. I found the simplesit LED blinking circuit on http://www.cappels.org/dproj/simplest_LED_flasher/Simplest_LED_Flasher_Circuit.html (note: any metteral taken from the above site is copyrighted to Dick Cappel) From there thru trial and error I designed my simplified Fireflies in a jar circuit. We will keep it simple and only do three LED's for now. Ime working on a 10 LED jar.
Parts list.
3 2N3904 NPN Transistors (Almost any other NPN or PNP from your junk box will work)
3 various resistors (I used 2-10K and a 1-1K resistor try different combos from the junk box)
3 100 ohm resisters (this one is a must or you MIGHT blow your LED's)
3 various capasters ( used 1-2200 UF 2-470 UF one 35V and one 16V try different combos.)
3 green surface mount LED (or any other color or kind)
1 Power supply of some sort. I used a Nokia Type ACP-7U. Out put is 3.7V DC at 340 mA I'm to cheap to buy batteries, and the cell phone for this charger became a dogs chew toy.
Various wires. the thiner the better.
1 mason jar. or some other type of inclouser.
Tools
Solder gun
solder
Optional but nice.
Universal Breadboard.
Prototype board.
DVM or AVM
Step 1: The simple cuircuit
When using the transistor only use the
emitter and collector. cut the base off or just bend it out of your way.
I will do a little cut and paste from the site I got the circuit from for those that are interested in why and how it works.
In this implementation, a common NPN transistor is used. In the circuit, a 1k resistor charged the 330 uf capacitor until the voltage became large enough to get the emitter-base junction to conduct. In the oscilloscope image, it can be seen that the peak voltage (yellow trace) was a little bit less than 9 volts. At this point transistor turned on quickly and partially discharged the 330 uf capacitor through the LED and the 100 Ohm current limiting resistor. The current wavform, which is the voltage drop across the 100 Ohm resistor, is shown in the blue trace on the scope image. Peak current was 26 milliamps, and the transistor continued to discharge the capacitor until conduction suddenly ceased at 60 milliamps. After the transistor stopped conducting, the capacitor began charging again, thus starting a new cycle.
To see oscilloscope image go to Simplest LED Flasher Circuit
What I did is no rocket science I used a common positive and a common negative and added more transistors. I also mixed and matched different combinations of resistors and capacitors so each LED blinks different then the others. In my mind the best blink fade in fade out combo is a 10K with a 2200 UF capacitor. it only blinks about once every three seconds but it looks more like a real firefly.
The image on this step is copyrighted by Richard Cappels at http://cappels.org/ , and is republished here with permission on this web page.
Begradoo says: Aug 9, 2011. 10:37 PM
I am confused.
I built this circuit to your specifications and to the original designs specs.
The LED (3v Amber) lights up to a dim glow and stays on at 12 volts and does nothing entirely at 3 to 11. I tried reversing the 2n3904s collector and emitter and the circuit doesn't function at all.
Any thoughts?
Earths_hope says: Jan 8, 2010. 2:14 AM
sorry, but you camera was dying in early 2007, and now its 2010! where are those upadated photos?
also, this is a coment bump
giving 4 stars
Dannos (author) says: Mar 9, 2010. 9:49 PM
Well thanks for the bump but that project has sense been torn down and the pieces es used in other experiments.  I had so much fun doing it I might do it again and now I do have a good camera so if I do it again The picks will be there
llaven says: May 29, 2007. 7:02 AM
Thanks for sharing this idea, i try make my own, i think that simple circuit will work like a Photovore but with a little eolic supply, obviously no with Solar panel supply, with this hack we only put the jar on window open and work in the night with the wind. Romantic idea, ha? :-)
digitrunner says: Mar 9, 2010. 5:33 PM
Lol with the jar open?? Wont the fire flies escape?
ampeyro says: Oct 5, 2009. 3:05 AM
wow, it's realy simple(the circuit), isn't it dangerous for the transistor? I'm trying to repair led flashing lights(the ones used in construction), the plan s to put another thansistor where you put the led(my leds uses 12 v and 2 amps at all) thanks
cosgrove says: Apr 9, 2008. 10:44 AM
Interesting Instructable, though you may wish to run it through a Spell Checker, some of the spelling was not so great
budsiskos says: Dec 15, 2007. 1:43 PM
can you please post a better circuit diagram
budsiskos says: Dec 15, 2007. 12:25 PM
how long did the blink last?
Dick Cappels says: Sep 16, 2007. 8:58 PM
One fellow who tried to build the basic flasher circuit had problems because he tried to run it from a 9 volt transistor radio battery. I just put one together using a 2N4401 and found that with a 1k resistor, it operated from 9.1 volts to 20.7 volts. A bit higher than you should expect from a 9 volt batter. Using a 2k resistor raised the upper voltage past the 27 volt maximum output from my bench supply. I appreciate the reference to my web page. Note that my copyrighted material remains my property, even though it is posted on this site.
Dannos (author) says: Sep 17, 2007. 6:02 AM
Wow thanks for commenting on my little project. I am on your site all the time. You have no idea how much I have learned from your site. you should post some instructables
Taotaoba says: May 28, 2007. 7:06 AM
Nice! Look forward to you final pictures.
Dannos (author) says: May 27, 2007. 6:11 PM
Just a little side note here. If you have a well stocked junk box the cost of this project can be 0
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
