simply build your own HAL 9000 by tollef
Featured
Step 1: Parts and Tools
What i used for this i found in my house, but i do have an unusual house so some of these pieces you might have to get creative with.
-about 1' of wire
-1 red LED
-Sandwich ziploc bags box
-soda can
-a switch of some sort(or if you dont mind just wire it so that its always on)
-cardboard(corrugated pref.)
-a clear marble
-black tape
-and a battery holder(2 x AA)
Step 4: Make a holder for the LED and marble.
I used a pen to be a holder for the marble at one end and the LED at the other.
-before you tape the marble on put the pen tube through a cardboard circle that has been painted black.
-after the tube is through the round piece of cardboard then you can tape the marble on to the tube.
-the tape the round piece of card board to a cylinder. I found a black ring but you could probably use a toilet paper roll or something.
Step 5: Slap some stuff together
-first paint the ziploc box black.just the box
-Next put the can in the box and push it through the hole so that the outer lip of the can is sticking out and is tight.
-Then cut some strips of aluminum from the can and glue a little square on the outside. Elmers glue works. find some screen and put it in the square. don't worry about white spots on the screen it dries clear,so just smear it on the screen onto the box.
-next you may have to add material on the outer part of the cylinder with the LED so that it fits snuggly into the can. Insert the LED/cylinder into the can, and put all the wires and everything in the box also to hide it.
(i put a hole in the back of the box for the switch)
commanderzhao says: Mar 29, 2012. 4:59 PM
I asked my boss if he had the components, and he gave me two 3mm LED's,
an angle mount switch, two perforated boards (circuit boards with bunches of holes, look it up), a 220 ohm resistor, and some advice. He said it would be best
if I used a resistor with the LED. Can I use THHN wire?
teslasrule says: Feb 18, 2012. 9:55 AM
So true about the root beer part lol.
burnerjack01 says: Jun 27, 2011. 11:50 AM
Now, hook it up with voice recognition and playback with an arduino to open your front door....or not.
ilpug says: Jul 24, 2011. 11:53 AM
for the agoraphobic maker
MethylPox says: Jun 28, 2011. 11:24 AM
Yes, read Clarke's novels... brings so much more to the movies.
Splaxx says: Jun 27, 2011. 5:56 PM
I would say this would be perfect for a complete desk mod... Rather than just the case... There are a few desk mods floating on the web that Incorporate the computer into the desk. This would be the PERFECT Theme for that type of mod.
Crucio says: Mar 15, 2010. 7:20 PM
You inspired me to make one, thank you.  I've always loved HAL.  This is my first version.  I hope to improve eye optics in later prototypes.
Based on the suggestions from commenters, I added a 3.5" audio plug and a transistor, so HAL's eye blinks/pulses with music.  And with a DPDT switch, the transistor is removed from the circuit, yielding a solid red light.
Super_Nerd says: Feb 25, 2011. 5:33 PM
Or hook the plug up to a windows computer and make him talk and blink. If you are doing that just to make it more real, add a battery in parallel with the plug and make sure its dim. I would also recommend downloading microsoft mike becase he sounds more like hal.
-Super Nerd-
tollef (author) says: Apr 3, 2010. 8:12 PM
 Thats awesome! really nice job. I like the blinking/ dimming idea
cyrozap says: Jan 5, 2009. 12:43 PM
Maybe I should do this w/ my xbox 360 elite. The eye would be the power button.
conrad2468 says: Jan 11, 2009. 8:59 PM
if you could make the green red but then how would you know if you got the red ring of death?
qwertyzzz18 says: Jul 15, 2010. 9:43 AM
You make the red green, so you get the GREEN RING OF DEATH!
ratgod says: May 22, 2010. 8:26 PM
You could use a blue LED and make a SAL9000
robo_bob says: May 24, 2009. 1:26 PM
lol i watched that movie and i hated it
tollef (author) says: Dec 13, 2009. 11:52 AM
 I think the book is better but i dont mind the movie. give the book a shot
Klaus Baude 123 says: Oct 1, 2009. 11:08 PM
Well that is simply your problem.
andyg960 says: May 20, 2009. 5:12 PM
how did you cut the can
Briguy9 says: Jul 6, 2009. 3:45 PM
It's easy, just take your handy scissors and cut into it, or for thin portions of the can an X-acto knife works as well.
app0 says: May 25, 2009. 9:03 AM
Make a computer case in the style of HAL!!!
conrad2468 says: Jan 11, 2009. 8:58 PM
have him play hal sounds but hook the + and - of the led to the speaker output and connect the speaker to to the thingy and the light should dim and get brighter with every word he says....if this is a little confusing i apologize....
phant0m_sp00f3ra says: Jan 14, 2009. 11:20 AM
i was gonna say that!! LOL Better idea!, hook up a mic in the aluminimum zone with a grid, then hook that to a computer and add some voice recognizion software. enable the audio outpout to the audio system you have and boom! you've got yourself a HAL 9000 entertaiment system HAL iTunes!! gotta do this :P but also connect the lights in my room and add a sensor for movement so we you step in he greets you :D
ironsmiter says: May 25, 2009. 12:57 AM
Oh, now you've gone and fired my imagination up.
Start with a small, surface mount, narrow angle, red led. solder black wire to the leads.
Glue the led to the dustcap.
Solder the lead wires to a rectifying capacitor, then the terminal points of the speaker.
Mount the speaker in the can/bezel and hook up to the motherboard speaker terminal.
Install Speak.exe
Play a looped "static space sound" from the movie(to give a constant low light level).
Have H.A.L. quotes replace system error message .wav's(brighter flashed when system message volumes exceed the background .wav volume).
Enjoy.
bounty1012 says: May 23, 2009. 9:38 AM
Lol Make him sing "Still Alive"
Kanein Encanto says: Jan 24, 2009. 6:07 PM
"I'm sorry Dave, I'm afraid I can't play that. " HAL & iTunes, sounds like a recipe for a little disaster. :) Love the idea of doing this as a case mod too, if only you could pipe system warning sounds (customized for HAL of course) through a second sound card so only they would cause the light to flicker, while regular sounds, IE playing your MP3s wouldn't make the light flicker...
xenor says: May 24, 2009. 5:05 AM
just chuck in a second sound card to yr pc. with a little messing around you should be able to specify which application uses each audio output device, but there would probably be a few things hard to change.
phant0m_sp00f3ra says: Jan 25, 2009. 5:54 AM
LMAO you got all the reason m8, OMFG i luv your idea too! ut would be great,
SkunkFox says: Feb 19, 2009. 9:04 PM
This would actually be a perfect mod for the xbox 360, would only require swapping the red/green led's around to make it work to. you can still use hal's eye as the on/off button to. Though the cd/dvd slot might be abit of an issue, but from the looks of your model that wouldn't be much of a problem to adjust it slightly for a sping catch latch to be custom fitted inside to open the top of hal to remove cd's easily from it. All in all nicely detailed instructable. Did think of another idea, possibly using it as a custom webcam housing though the red led might color the webcam picture red... which would be ideal for some rather interesting webcam shots. Could even install it by the front door, adding a few simple modifications you can make it into a nice security setup for knowing who's there, and when if you used a hidden motion detector to take a picture of folks as they passed by or entered your house. just some thoughts. Have fun now!
FaqMan says: Jan 12, 2009. 8:25 PM
This is awesome I agree with the others use a computer case to complete the image of Hal. Still tohugh great job.
cd41 says: Jan 11, 2009. 6:24 PM
can you say computer case mod?
THAT WOULD BE SICK!!!!!!!!
cd41 says: Jan 12, 2009. 7:45 PM
I'm gonna try it with a none working computer but just for design, cd rom hole and other e-sentshals of course maybe mae the power buttton the big lense eye/light thing
tollef (author) says: Jan 12, 2009. 10:55 AM
The computer case mod was my first idea, but i thought i would just do this for now. And Ill look into the voice/LED dimmer thingy,haha
Bongmaster says: Jan 12, 2009. 5:09 AM
im sure he had a glass dome over the whole eye, lens style..
cd41 says: Jan 11, 2009. 6:19 PM
this is finally a simpleInstructable with a cool affect that i have all the stuff already for
phant0m_sp00f3ra says: Jan 10, 2009. 9:47 PM
you sir rock the hell out of me. i Gotta do this! and make it my iPod dock
dung0beetle says: Jan 4, 2009. 10:51 PM
Barqs is better, i agree.
skaldedgrifon says: Jan 4, 2009. 8:45 PM
Ha, this is neat and has a great 'do-ability index'. What a neat way to build an affordable and fun movie prop. Thanks for sharing.
moisture says: Jan 4, 2009. 5:23 PM
Just what do you think you're doing, Dave?
http://www.imdb.com/title/tt0062622/quotes
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
