Single Stage Coil Gun With Revolver
3,340
34
4
Posted
Introduction: Single Stage Coil Gun With Revolver
This single stage coil gun was made from things I just had lying around my house.
Step 1: Step 1
First you gather the materials box pipe, hot glue gun, 2 15 inch by 6 inch pieces of oak wood, rosin core solder, soldering iron, duct tape, lots of wire, 7 capacitors, a button, a risistor, an LED,  a 9 volt battery connecter, scissors or wire cutter, and a wood saw
Step 2: Step 2
Make the following: a pipe with wire wrapped around it, 6 pieces of pipe wrapped around another pipe, and your wood stock with a large section chized out
Step 3: Step 3
Attach the coil to the revolver with hot glue and put the wires through the center of the revolver
Step 4: Step 4
Solder the capacitors in a series
Step 5: Step 5
Solder the 9 volt connector to the capacitor series.
Step 6: Step 6
Now solder the LED and the risistor to the circuit and fit it in the stock.
Step 7: Step 7
Solder the wires from the revolver to the stock wires and add the button.
Step 8: Step 8
Finally you secure everything with hot glue and add some extra pipe on the top. When done you clip in your led and your ready to shoot. I've found That paper clips work the best, the first shot I took with mine resulted in a paper being shot across the room, but it's not all fun and games this is an actual gun and is extremely dangerous plus the high voltage can give a lethal shock so I advise extreme caution.
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    5 Comments
    You say in your instructable to wire the capacitors in series, but your picture shows them to be wired in parallel..
    What are the capacitor values and voltage ratings? Are you sure that they are in series? Because the photo is not completely clear but looks like soldered in parallel.
    300v, 50 uf. Your correct, I'm sorry I'm new at this electronics stuff but I'm learning. I just followed a scamatic I found online. Thank you for spoting my mistake. And I apologise
    thank you for the nice comment I would love to vote for you
