Slim Elastic Wallet
16,928
93
6
Posted
Introduction: Slim Elastic Wallet
Recently the Instructables office found out about slim, an elastic wallet on kickstarter that made lots and lots of money. We wondered what it was and what it was made of... and once I figured it out I decided I would make my own! An elastic wallet is a neat idea, and super cheap to reproduce for yourself.
This super slim wallet is made from two inch wide sports elastic, and it's perfect for storing credit cards. You could even store a little folded cash in it. Also, the wallet is pretty easy to sew - since it's made from elastic all you'll really need is a sewing machine and a few minutes. A serger would be even better. :D
Step 1: What You'll Need:
  • a sewing machine or serger
  • 2 inch wide elastic
  • scissors
  • measuring tape
  • thread to match the elastic you buy
I bought my elastic on etsy from Puffytots - they have an amazing amount of elastic in all different colors and patterns. :D
Also note that I am using contrasting thread for this project so you can see where and how I'm sewing, but you should really stick to matching thread - it'll look so much better.
Step 2: Trial and Error
Sewing the elastic can be pretty tricky at first, and you really need to make sure your stitches are secure. :D
I made three different versions before I figured out the perfect dimensions and how to sew it just right. 6.5 inches was too tight, 7.5 inches too large. Straight stitching did nothing to keep the elastic together - and large zigzags didn't do much.
In the end I determined it was best to use a small zigzag stitch, stay close to the edges, and double and triple stitch for staying power.
Step 3: Cut Your Elastic
Cut a piece of elastic 7 inches long.
Step 4: Zigzag Both Ends
Use a narrow zigzag stitch for this. :)
Zigzag stitch each end twice, right next to the edge of the fabric. Just go over your initial stitching with the second line of stitches.
Once an end has been stitched, trim it so it's neat. Then repeat all the steps with the other end.
Step 5: Sew the Ends Together and Flip
Place the two ends together and sew. You'll do the small zigzag stitch and go over your stitching twice again. :)
Once it's sewn, trim any loose end and flip the elastic to the other side. At this point you'll be able to see if your stitches are strong enough!
Step 6: Sew the Bottom
Align the elastic so the seam is in the middle, and then sew edge to edge along the very bottom using a zigzag stitch. Stitch the bottom seam at least twice and then trim any loose ends.
Step 7: Carry Your Cards!
I've been able to get up to six cards in mine - which is more than enough. I can also do three cards and a small bit of money. :D
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
6 Comments
This look so good. My dad actually talked about a creditcard holder and then i accidentally saw this. Thank you :)
Hmmm...Could you sew a "W" and get three pockets (two on the top, one on the bottom)? Like so:
So if people bought their own elastic these would cost at most $2 in material (as low as $.50 in bulk). Then just a couple minutes to turn it into kickstarter gold!
This is a great idea and an easy to follow project. It certainly looks like it holds the cards securely.
What is your experience with the completed wallet so far?
Does it slide in and out of your pocket pretty easily?
I ask because I will probably be hand sewing this thing, quite a task for a guy who's all thumbs. But I'm pretty sick of my current spine punishing model and I'd like a front pocket option.
Where do I pledge my $50 to get the case with the X on it?
The X means it costs more, right?
A wallet that carries "a small bit of money" is just what I need, since that's all I've got ;) But seriously, great idea and great 'ible. Nice photos to inspire the GF to fire up her Husqvarna and build us some clever new wallets!
