3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
small breadboard power supply
Having a huge lab bench power supply on your desk can take up a lot of space. Sometimes you just need a stable low current 5-Volt power supply to test a simple breadboard project. This project shows how you can make a power supply that almost takes 0 space.
Step 1What you need
What you need
To make a power supply you will need the following:
Materials:
-Solder
-wood glue or other PVA based glue
-(black) spray paint
-toilet paper
-old newspaper or equivalent
-wire with jst female connector (for power supply)
-wire with jst male connector (for in breadboard or electronics project)
-heat shrink tubing
-a fresh 9-Volt battery
-a not so fresh 9-Volt battery
-low drop voltage regulator, i used LM2931AZ5 (check the datasheet)
-2 ceramic capacitors 100nF (check the datasheet)
-1 electrolytic capactitor at least 100uF, is used an old 470uF (check the datasheet)
-pin layout: since you're checking the datasheet anyway, make notes of the pin layout.
note: the datasheet of my regulator said the ESR value of the output capacitor is critical. From my personal experience, you need two 100nF capacitors and one electrolytic  capacitor, or else it will oscillate audible!
Tools:
-multimeter to test the circuit
-pliers to open the battery
-scissors
-soldering iron
optional: a breadboard circuit in need op juice.
Skills:
-handling a soldering iron
-patience
If you already have a 9-Volt battery clip, you can skip step 2.
If you don't want to paint the power supply, you can skip step 11.
8 comments
Sep 11, 2011. 10:02 PMratgod says:
I love the idea of toilet paper and wood glue, I've never thought of that before.
I have something similar but it's much bigger and it has a socket for the standard 9V wall supply connector. I'm too cheap to buy batteries ;)
I think I will build one of these though, excellent for building a portable lab.
Jan 4, 2011. 11:15 AMjanw says:
Nice instructable. I did build a similar thinga long while ago but mine had a switch added so that it could switch between 5V and 9V. I must admit that I never use it anymore. most of the time I use power from a USB port to power my breadboard for lowcurrent 5V projects
Jan 5, 2011. 10:15 AMjanw says:
you could add a small quick fuse to avoid blowing your usbport
Dec 30, 2010. 12:44 PMaelias36 says:
Nice instructable! Question though, (i'm probably gonna sound like a complete idiot for asking this, but,) what's the point of all the capacitors? Wouldn't the regulator work just fine by itself?
Jan 4, 2011. 1:12 PMaelias36 says:
Oh, I never knew that. Thanks.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:critiacrof
