3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
small hovercraft
small hovercraft
a simple,free and safe hovercraft model!
Step 1Things you need!
things you need!
u need:
1 a big plastic or paper plate
2 a pc fan
3 some batteries (12 volts)
4 some tape
78 comments
1-40 of 78next »
Apr 6, 2012. 12:20 PMride on toy dude says:
instead of using two double a's and a nine volt
you should use a tiny a23 size battery.
Mar 31, 2012. 5:14 PMspiderloco says:
I thought of this idea also. After cutting the paper plate and attaching a 12 volt fan motor from an old computer to it I powered it up to 19 volts (the biggest pwr supply that I have laying around) and it just about will hover with the weight of the motor. The voltage will have to be increased well beyond the tolerance of the motor to get a good lift. We need a better motor/ fan combo
Mar 30, 2012. 7:37 PMride on toy dude says:
i was thinking of doing the same thing except with a small motor, propellar, a bowl, and a button cell battery.
Apr 22, 2011. 11:24 PMsaransaleen says:
Good idea !! but let me gie a another replacement for the batterys ..... the red and black wires of the PC fan to a USB cable..... just cut off the the end that u connect to the load (ex : mobile).. inside u see red & black wires just connect the red wire to the fan's red wire and the black wire to the fan's black wire.....
Mar 6, 2011. 11:00 AMShemySheza says:
is it safe to connect a 9v and AA together?wont the AA explode?
:P
Mar 4, 2011. 1:02 PMShemySheza says:
:P
Jan 20, 2011. 4:03 PMbenduy says:
the reason the hovercraft spins is the grooves in the plate, how heavy is the fan.
Nov 29, 2010. 5:08 PMRaziel7 says:
maybe you could make an instructable in spanish?
There should be a Spanish section for instructables.
I speak fluent English and Spanish so if you ever need help translating hit me up.
Nov 23, 2010. 10:44 PMwin1213 says:
there is one problem with all this hovercraft and that is when the fan spins...the whole thing spins as well...so if anyone have any idea to solve this problem please help me out =)
Jun 29, 2010. 5:54 PMvignesh1230 says:
I'm sorry but i do not think that this qualifies as an instructable. You instructable needs more detail. For step 4 just putting the batteries would not do. Tell them what sides to put together. And for step 5 you need to tell them where to put it and how to set the perfect center of gravity not just put it in place. So please try to make this instructable better.
Jan 13, 2007. 7:56 PMhgseawave says:
Question from my 10 year old: it does not seem to work for me..! we bought a new fan and new battries. the combiantion of batteries the directions say to put together does not work. the hovercarft does not seem to suppor tthe batteries and it spins very slow. the directions don't explain where to attach the wires to the batteries.
Jun 29, 2010. 5:37 PMvignesh1230 says:
OK did you wire it it series or parallel? Series makes the voltage go up and parallel makes the amperage go up. for more info go to http://electronics.howstuffworks.com/battery5.htm. I might have gotten the series and parallel mixed up cuz i'm only 12
Apr 8, 2009. 5:19 AMmman1506 says:
did you use new batteries (thats what always happens to me)
Apr 17, 2010. 1:54 PMzigzagchris says:
is it bad to use 2 9v for a 12v fan. It runs like it but will it break it?
Sep 13, 2009. 12:14 AMDEMONSLAYER1 says:
A fast response would be appreciated cos its due next week and im away next weekend thanks bro
Sep 12, 2009. 11:53 PMDEMONSLAYER1 says:
was your fan very heavy or was it a light computer fan?
Sep 12, 2009. 10:52 PMDEMONSLAYER1 says:
I'm tryin it 4 a skool project. should be fun. I LIKE TOAST!
Sep 7, 2009. 12:39 PMthealeks says:
dude! i made this and powered it with a 12v adapter and it rocks! thanks for posting this!
Jul 1, 2009. 1:44 AMwin1213 says:
can some 1 help me cus my whole hovercraft will spin when the fan spin
Feb 25, 2009. 3:04 AMFRABBAfrabbaFRABBA says:
i made it but mine doesnt work so i made one with four 50mm fans and rechargable batteries and it works very well
Nov 21, 2007. 9:10 PMsajada says:
Just wondering... is there anything else to replace the pc fan? you know Im still 13 so i dont have acces to those kinds of things. would a couple of those disposoble fans work? ya' know placed strategically? with all do respect
Jan 18, 2009. 11:02 AMFXwhiz30 says:
all you have to do is get an old windows 98 or 95 and disect it to get the fan!
May 30, 2008. 10:33 AMApemza says:
Hey man, you can buy one in the computer stores - usually uinder 3$ !
Feb 26, 2008. 12:00 PMdean-101 says:
hey, i no a site you can get those fans cheap it is www.maplin.co.uk they sell them in all sizes and they even sell ffan kits for making the likes of helicopter(small) and hovercrafts and stuff.
Feb 18, 2008. 8:04 AMNotbob says:
its not that hard to get comp fans when I was 12-13 i would go and cruise the local goodwills and pick up really cheap old comps and salvage them for parts, ive (still got fans lying around) you should try it its really easy.
Feb 9, 2008. 7:15 PMi are ben says:
were can i buy napkins?
May 11, 2008. 3:40 PMultrauber says:
Grocery store.
Apr 25, 2008. 5:40 PMmysterious ninja of fire says:
i made mine out of cardboard plate and bent the rim up so i could put like balls in the rim and the rim acts as a bumper lol
Mar 12, 2008. 4:06 AMwin1213 says:
i tried this a lot of time but it wont float but jus vibrate i think its too heavy HELP ME
Apr 25, 2008. 5:13 PMmysterious ninja of fire says:
try taking the fan out and flipping it around
Apr 23, 2008. 8:00 AMtheosullis says:
Would a vacume engine work?
Jan 9, 2008. 3:27 PMqwerty90210 says:
I made a "Hover car" model similar to this but I used cardboard for the bottom and a "skirt" with a grocery bag.
Mar 25, 2008. 9:27 PMqwerty90210 says:
9v it went out fast but it was enough 4 the science fair
May 19, 2007. 9:58 PMmondaymonkey says:
I have been working on building a model hovercraft design for a couple weeks on and off. I have decided that in order to have a floating hovercraft. A) you must have some sort of skirt, cuz hovercrafts don't use air thrust, but air PRESSURE. But more importantnly( B) YOU MUST have a very high speed motor. A small prop, preferably a lot of blades. C) It needs to have a large surface area, because it is more efficient to load say 1SQF at 30PSI than 1/2SQF at 60PSI. The above model does have a relativly light, and large prop motor/fan setup. For it to hover better, i would put a larger plate, and attach a skirt by putting a garbage bag to the bottom, attach it somehow to the middle of the craft, and make small holes toward the center of the skirt..... ill make a instructable soon NOTE: It needs to be HELLA light
Jan 22, 2008. 8:24 PMrockman says:
i rekon its a great idea but the batteries are to heavy for the fan so what i did instead was extend the wire then hook it up to a bigger battery and it works fine
Oct 1, 2006. 10:03 PMabbtech says:
Looks great! Got a video?
1-40 of 78next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:andresm
