Spinner Motorizer Homemade
Published
Introduction: Spinner Motorizer Homemade
About: the a b c approach is not for me .all feedback welcome. thanks for looking. if you would like some assistance or are interested in purchasing something don't be a stranger .
under construction
goes from half second to 10 second exposure. i finished this shortly after lomo released their official one for silly money, they went wireless, i went adjustable.
Step 1: You Get the Idea.
lead for stability, 10 battery's, can use ac adapter, went for a slider pot insted of rotary, remote control is from part of zenit shutter and car phone charger. rubber band drive pully made by friend with access to lathe, i tried a diy but it was a bit naff.
Step 2:
early prototype tried adding a light but it was most ineffective, the project was shelved for a while 23march 2011. incidently having batterys on top and light on front balenced well so high speed could be used
Step 3: What the Spinner Does
first image 10 second exposure caught the entire blackwall tunnel
second image turning slowly by hand not the smoothest action hense iffy exposure values
third image normal use but then polar coordinated in photoshop (thats an instructable in itself, im meaning to show a good technique at some point)
Step 4: Loosen This Screw to Get Handel Off
Step 5: Get Sizes Right
the pully wheel, and the flat side spindel
t tried modifying an existing plastic pully wheel from a sash window (size close)attached to nut and bolt put in power drill and file, went a bit oval so i got al at the toolmaking department to adjust a al-u-min-ni,um cam belt pully (also from mfa, was part of the 1st prototype)
i got the flat sided spindel a bit wrong permanent attached to gears so a screw in base of spinny bit keeps it level
Step 6: Sockets for Remote and External Power
best not mix em up think i got the jack socket cut off terminal right, normaly used to cut speaker on audio devices when headphoning
Step 7: Speed Range
         rpm devided by 60
_______________________________________
approximate (changes) length of 360 photo neg devided by width of image slot
think this is formula i used, i just wanted a rougth idea what to engrave on the box
Step 8: The Box
its a money box the slot came in handy ,needed lengthening to accomodate slide resistor
Step 9: I Bought the Gearbosx From Mfa 3000:1 Ratio
they got website, they hour drive from me,they in big black barn with shouty dog, i wanted to get touchey feeley with the products, quality box forget the price 4.5v to 15v ,i took plastic cover off to help fit and i like the look
Step 10: Pwm Speed Regulator
parrently better than just a pot, it uses a chip and pot , i swaped the twisty type with slidey type, then i thought can it go slower, so i pot random resistor in series used switch to cut it in out circit to maximise speed range
Step 11: Slider Does Same Thing As Twisty ,
3 wires used meter to figer out
Step 12: Some Wires to Connect Everything
Step 13: 15volts Worth of Batterys and Some Lead to Keep It Steady
well i had to use the lead for somin
Step 14: Nice Gears
wrrrrrr
Step 15: Super Pully
its epoxted to the box and the gearbox pully goes through the middle, can you see the leveling screw mentiond elsewhere
Step 16: The Slot
just incase you were wondering what i was on about
Step 17: The Light Component Remains From Prototype 1
maybe one day....
Step 18: And of Corse the Remote Control
with a 3.5 to 2.5 jack adapter i could use the one from my canon dslr! ha,
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    6 Comments
    These are mods I've been thinking of doing with my Lomo Spinner - More information please!
    added some in no particular order hope its of some good ,let me know, its a shame lomo didnt do a better job of their own one , i did suggest to them.
    Brilliant, thanks!
    I think the official Lomo Motorizer rotates too slowly, and is too expensive to justify purchasing it, and I'm glad I didn't get the Motorizer when I bought my Spinner.
    Unfortunately I've had few problems at airport security, as the original handle has a metal rod right down the centre, which shows up on the X-ray machines.
    glad u like..think i paid a total of about £40 for the parts,my prototype used a cheap gearbox and was not up to the task ,tho it was badky mounted. wonder how security would react to a locked metal box full of wires switches batterys mechanics and lumps of lead,.with a remote wire. kriptonite?
    I'm intrigued, but I don't totally understand what this does. it takes photos?
    oh my its late..yes it does ,it goes round . scans onto the film like old digi cams did, of like a flatbed scanner sept it goes round, oh my its late, some sampels
    http://www.flickr.com/photos/83675368@N02/sets/72157630810829486/
