spiral patterned " layer " garden
 by pink.bat
After many, many years of gardening and trying  many methods to combat weeds ( Like raised beds, mulches, landscape fabrics, scrap carpet , newspapers, and combinations of those) I have found that "layer "gardening is just about the best method for raising vegetables. The trick to the method is to layer and layer compost and grass clippings and other yard waste in a deep pile 18 to 24 inches thick over the whole garden. You can start with turning over or rototilling your garden spot. Or if you have the time, just start the pile a few months before you plant. You plant through the pile and as the season progresses, and the pile naturally turns to compost/soil , you add more compost and clippings.  Few weeds make it to the surface , and if a few do, you can pull them out of the loose soil with ease. One thing that you must not do is to step on the garden soil.  Walk- ways are very important. A traditional row garden will work, but I like a circle because of it's beauty and design potential. The circle gardens I have had before had a more formal layout of crossed paths and symmetrical  plant layout. The problem  with the pie shaped wedges , is that at the "fat" end of the wedge there is always a spot where I just could not reach . More often than not ,  I wound up stepping on the soil and compacting it. That is when I thought of using a spiral path . Now I can reach both sides of each plant in the garden. No more spots where I have to  go" oops! stepped  into the garden again !"  . As for the paths , I used brick because they are easy to lift and lay in a pattern The garden does not need to be "dug" ever again and after a few seasons in the same place you have a really lush , weed free garden with fantastic soil.
Step 1: Spiral pattern
 The ground has been rototilled in a large circular plot. The compost and clippings have been layered on and the bricks for the walkway have been put down. Early March here in Texas.
Step 2: Plants are growing
 I put in a simple vegetable plot of Tomatoes, Green and Hot Peppers , Yellow Squash, Eggplant Cucumbers and a blanket flower and One Giant Dandelion .
Step 3: Mom's Helper
 I used to use soaker hoses buried in the dirt under the mulch. But one part of weed control is not to water where it is not needed. Now we hand water each plant about once a week.
Step 4: Getting established
 The plants are growing and I have added uprights for the cucumbers to climb. The stepping stone in the foreground is a plain gray stone that has been decorated by hot gluing fish gravel  to it. This is the start of third year that the stone has been outdoors.
padawanspider says: May 16, 2011. 1:30 PM
creative design! Definitely good inspiration to think outside of typical squares and rows. Thanks for posting!
kirnex says: Feb 10, 2011. 7:06 AM
Looks awesome, Pink Bat. You guys did a terrific job. Love this idea. Am going to try it this spring! Thanks for sharing.
XTrunksieX says: Jan 3, 2011. 8:15 PM
I think this is a great idea! Very beautiful and a great way to combine good composting habits and creative weed control. I'm tempted to try it as soon as possible. Well done!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
