Splice a Loop in Rope or Cord
2,061
11
Published
Introduction: Splice a Loop in Rope or Cord
About: I think my interests tell a lot about me, I'm a multimedia artist which means I work in whatever medium grabs my attention, paint on canvas is very relaxing and acrylic paint can be mixed with paper to make ...
a loop on the end a rope or cord comes in handy in a lot of ways, sure you can do a quick knot but I like having a more permanent set up. Different types of rope require different methods, here's what I did with some cord I got from the dollar store. Before you ask why take the time, this took me less than 5 minutes including taking the pics
Step 1: The Start
as soon as I unwound the bundle of cord from the dollar store it began to unravel. I cut off about a foot and flamed the new end.
Step 2: The Loop
I decided on the size of the loop by roughly forming it and pinching the long end of the cord at the base of the loop, a slight twist opened the cord wrap and I passed the end through, twisted it back tight and opened the next wrap again passing the end through and repeated that process for about 3 inches
Step 3: Wrap It
this type of splice doesn't really need to be wrapped which is another way to secure a loop in a line but I had those cut off pieces right there so...
 lay your wrapping line inside the loop, holding the short end against the line, wrap the long end around so it secures itself and continue wrapping until you run out of wrap and pass the end back through the last loop and pull it tight
Step 4: Finish
I cut off the short ends (flags) and heat sealed all cuts, now the cord is ready to be used
  • Casting Contest
    Casting Contest
  • Oil Contest
    Oil Contest
  • Woodworking Contest
    Woodworking Contest
3 Comments
Simply very useful technique that I didn't think of myself. This makes a very strong loop that I could see being used to even hold a string to a makeshift bow or anything that has a fair bit of movement. It will be used in future projects, cheers!
( Thanks for the welcome to instructables too! )
Thank you Atom, splicing an eye is probably as old as rope but it's a dying art. Here I did it all by hand but in a lot of cases you need a tool to spread the twist of the rope, a screwdriver works in a pinch
