Introduction: Spoon Money Clip
For those who don't want a bulky wallet stuck in their back pocket, there is a money clip. But why spend a bunch of money on a lame clip that looks like every other one out there? Make your own out of a spoon! It only takes ten minutes and costs less than a dollar. Everyone at your local hipster bar will think you are cool and creative when you pull one of these out to pay for your PBR.
Step 1: Find a Spoon.
The first step is finding yourself a good spoon. Your local thrift store should have a bunch for cheap. Just pick out one(s) you like, most of the time they only cost a quarter. Silver works the best but any metal is fine. Teaspoon sized spoons (not the measuring kind) work the best, although i have made clips out of big soup spoons. The larger the spoon the more likely you may crack it during the process (unless you want to bust out a torch and anneal it). Try to pick a spoon with a flat handle, it makes bending a whole lot easier.
Step 2: Assemble Your Tools.
Next you will need to gather the tools you will need to smash your spoon. A hammer, a screwdriver and a piece of scrap wood is all you need. The hammer should have a smooth face, so as not to mark up your spoon when you hit it. Pick a screwdriver with a larger shaft, you'll see why later.
Step 3: Start Smashing.
Place the spoon facing down on the scrap piece of wood so it doesn't scratch up the surface you are working on or vice versa. Hit the spoon with the hammer... pretty hard. Try to move around the head of the spoon as you go as to not hit the same spot too much. The spoon will begin to flatten out... keep going til it's completely flat. The handle will start bending up, don't worry about, you'll be bending it later anyway.
Step 4: Fold It in Half.
After you have flattened the spoon you need to bend the handle over on itself. This is where the screwdriver comes in handy. Use your hands to bend the spoon around the shaft of the screwdriver. Start the bend 1/4 inch back from the head of the spoon. the end of the handle should stick out beyond the end of the head of the spoon. Once you can't bend it anymore by hand, hit it with the hammer a few times to get it the rest of the way. The flattened head and handle should be touching slightly.
Step 5: Insert Money and Enjoy.
You're done. Put your cards and cash in your new money clip and hit the town.
