What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
in this case i removed the numb lock led and used a bright blue led inside of a brass tube i mad to create an accent light controlled by the numb lock key since almost always on it works out well.
Is the light coming out of a hole? Or is there some cover? I see a design and don't understand if that is part of the light or part of the cover?
One more question on putting keys onto plastic key: is it only glued? Is there anything for structural stability? A shaft? BTW, this is way cool. Thank you for your post.
A piece of braided steel was used on the inside of the brass pipe its as long as needed for the soldered shut side going down and the cap soldered on the other end holds it in place. To get the braid get a length of coaxial cable (tv cable) and remove just the outer pvc plastic. the next layer on the inside of the cable will be woven wires /////\\\\\\////// over layed . Slide this down the next layer of foil covered foam and wire. Cut the foam covered wire off and let the braided wire go cut off the braided wire off and use the same style push together slide to work it onto existing wire and slide it inside the brass tube with the led to make an inside grill.
love the design, but why blue? amber Led would give a more incandescent-steampunky feel I think, still i guess i can do that when i make mine :) thanks for the great idea :)
what about little mechanical flags that pop up to indicate what mode your in, like traffic signals... you know, the sort they had before traffic lights... now, that would be steampunk!
