Introduction: Strawberry Loom Band Charm
Today we will be making a strawberry charm made of loom bands
Step 1: Loom Position
make sure your loom is as shown
Step 2: Placing Your Green Bands
1. place double green bands from the top center peg to the right
2. place double green bands from the top center peg to the left
Step 3: Placing Your Red Bands
1. place double red bands from the top right peg to the second then from the second to third and from the third to the middle fourth peg .
2. now place double red bands from the first middle peg to the second from the second to third and from the third to fourth peg (like the second photo)
3. place double red bands from the top left peg to the second left peg and from the second to the middle third peg . (like the third photo)
Step 4:
1. Take your hook and wrap a green rubber band around once to make two loops as shown in picture one, then place it on the top right peg repeat this step and put the other on the top left pegpeg
2. wrap a red band around once on your hook to make two loops and place this cap band on the third middle peg
3. wrap a red band around your hook twice to make three loops and place that cap band on the fourth middle peg
Step 5: TIME TO LOOP!
Start from the last middle peg go behind your cap bands and grab the first double bands, loop it to itself, then go back and grab the remaining bands loop it back to itself from there keep looping until the last leg on the right
2.from the third middle peg go behind the cap band grab your first set of double bands and loop it to itself go back to that peg grab the remaining bands and loop it to itself keep looping till the end at this point it should look like my third photo
3. loop from the second left peg to the first left peg and from there go behind the cap bands grab the only set of double green bands loop from the first left to the first middle peg it should look like the forth photo . go to the last right peg and do the same from right to the first middle
4.take your hook and put it through all the bands
5.take a single green band and place it on your hook
6.pull the single green band through all the bands
7. create a slip knot pull tight
now you can take it off the loom
HOPE YOU GUYS FOUND THIS EASY AND I HOPE YOU LIKE IT ❤❤
