3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
sugru - how to make your own DIY sugru sachet / save left over sugru
When I open a 5g sachet of sugru I tend to use it all but sometimes there is a little piece left and often this is where I get really creative, thinking of what to do with the leftover piece.... :)
...some people like to save their left over sugru for later but as sugru is a moisture cure material, it is very difficult to stop it from curing :(
This is a simple and easy to do project to help you save your left over sugru for later :)
N.B. your DIY sachet should save your sugru for a while but will not as good as the original sachet
The sachets that your sugru is packaged in is not ideal to use for DIY sachets as there is a residue of sugru there that does not allow for a good seal :( The pouch material is clean which makes it ideal for the job.
Step 1Use your sugru pouch
To make your DIY sugru sachets, you can reuse your sugru pouch for it's moisture barrier foil.
You can make 4 good sized sachets from the Smart Hacks Super Pack and 4 smaller sachets from the Smart Hacks Pack :)
45 comments
1-40 of 45next »
Jan 18, 2011. 1:42 PMkillerjackalope says:
You know if you open one side of the 5g sachet you can reseal it with those food bag sealers really easily, it'll be a better seal than folding alone plus no need for chopping up, I can attest to it working for a few days.
Jan 21, 2011. 12:01 AMshanmugammpl says:
You could add silica gel in the bag! so as to remove moisture in the bag! because food bags generally are quite big!
Jan 21, 2011. 9:04 AMtimothymh says:
That would do exactly what you want to avoid. I'd prefer not doing anything counter-productive, thanks :)
Jan 21, 2011. 8:55 PMshanmugammpl says:
Why would it be counter-productive? isnt the idea to remove mositure? :S
Jan 22, 2011. 5:37 AMtimothymh says:
No: If I'm not mistaken the whole idea is to keep the moisture in, to keep it from drying out. But maybe that's not true...
Jan 22, 2011. 6:08 AMshanmugammpl says:
It says that sugru cures with moisture... and since the air is moist sugru cures in air...at room temp. therefore you would want to remove any moisture from the package!
Apr 16, 2011. 2:18 PMgnuoy4 says:
Please, please.......All of you - try to use proper grammar. I would greatly appreciate it, since this is one of the few websites I allow my teens to view. Former Prof. Thank you.
Apr 17, 2011. 6:40 AMtimothymh says:
Were we not?
Jan 23, 2011. 7:20 AMtimothymh says:
Oh. *shrug* Shows how much I know. xD
Jan 19, 2011. 3:53 AMkillerjackalope says:
I actually tkoo one of them apart in another sugru project
Jan 20, 2011. 3:58 AMkillerjackalope says:
Thanks, as for the comment on the wineglass one, so far moisturizer, fiber putty - the hair gel and olive oil have all worked great as a way to stop your hands sticking to it.
Jan 20, 2011. 3:37 PMbptakoma says:
Hey y'all. Use a bit of parchment paper (from the baking section of the grocery store) between your iron and any plastic you're trying to weld. Should help avoid icky situations.
Jan 20, 2011. 6:09 AMJikz says:
I really thought it was a condom at first....very comical - how to reseal your condom? But no, this is definitely useful and now I really would like to try some of this stuff on my tools for work!
Jan 20, 2011. 12:30 PMcriggie says:
Yay! I'm not the only one with a dirty mind!
Jan 20, 2011. 11:29 AMenganear says:
I have read about making your own faux Sugru from silicone caulk and corn starch, I must try this sometime...
Jan 20, 2011. 7:03 AMevilution says:
I find that it's very easy to separate into 2 or 4 pieces whilst it's still inside the sealed packet, then I stick the packet in my cheap eBay heat sealing machine.
Make separate compartments for each piece and use them as you see fit.
Jan 20, 2011. 8:18 AMevilution says:
Well technically you can't reseal a packet that hasn't been opened but I wouldn't want to appear pedantic lol.
Yes, I partition the sachet before opening and it seems to have preserved the unopened blobs perfectly. You can always do 2 seals right next to each other just in case if you wanted.
Jan 19, 2011. 6:57 AMFoxtrot70 says:
I don't mean to sound too uninformed. What is sugru? A sentence or two explaining what it is would be helpful then, go into the instructable.
Jan 20, 2011. 7:38 AMFoxtrot70 says:
Hi James - I just viewed the sugru website. Very interesting, I see this could be used as a really quick mould compound for a quick one-off item. Thanks for the reply and the link.
Mike
Jan 19, 2011. 3:18 PMducktape100 says:
were can i buy it?
Jan 20, 2011. 4:56 AMducktape100 says:
thank you
Jan 19, 2011. 10:38 AMJayefuu says:
Massive kudos to you guys for publishing this. Most companies selling perishable products wouldn't want their consumers to know this kind of trick for fear of them not buying as much of it. If anything, knowing I can do this would make me open a packet sooner rather than waiting around for several fixes to do.
Jan 19, 2011. 7:35 PMThe Ideanator says:
Agreed. I've been looking for something to do heat seals like that for a while, but haven't thought of anything quite so simple (though a rig with the heating element out of a toner printer would be cool).
Jan 20, 2011. 1:05 AMskimmo says:
that,s pretty damn savy, do you think it will work for mi goreng flavour packets?
Jan 18, 2011. 3:43 PMThamarBerber says:
I'm on this website for a while now, and I've seen several ideas already, how to use Sugru. And I love them.
But...What is it!?
What is the material?
What's it made from?
Is it clay? Is it plastic?
Is it sticky? I think you have several colours Sugru, isn't it?
I'm asking, because we might have an alternative in The Netherlands I can use. Just (very) curious.
Jan 18, 2011. 11:10 PMMister-B says:
It is like a clay first, and after a while it hardens to a silicone stuff. You can stick it to something, and it won't come of, but after it hardens, it isn't sticky anymore. It's patented and pretty know so I don't think you'll find anything like this. But it's from England and the shipping is really cheap. So just buy some on sugru.com
Jan 19, 2011. 9:14 AMThamarBerber says:
Thank you very much for answering, Mister-B. :)
Jan 18, 2011. 11:15 AMDemonSpawn says:
haha, I glanced over at the picture when scrolling, thought it was something dirty! xD Very nice idea, too bad i cant get sugru in South Africa... :(
Jan 19, 2011. 4:56 AMDemonSpawn says:
Thats Awesome!! how long would it take to get here though, because judging by my other parts ordered from America, I'd be better off walking there to fetch them! :D
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
83
Author:projectsugru(sugru)
