introsundial, compass, spirit level. All-in-one time piece.
Who wouldn't want to have a wearable sun-dial as part of a time traveller's outfit?
My sister and I always thought a wrist-mounted sun-dial would be completely impractical, Not so.
(although it's still nowhere near as convenient as a normal watch)
To have a functioning sun-dial outside of your garden, you need to know where north is..
Also, you need to keep it level. How do you combine a shadow, a compass and a spirit-level, and fit it on a wristband?
Researching existing sun-dial designs, one type in particular caught my fancy: the equatorial dial.
It can function at any latitude (if you know what it is) and some of them actually give you true north when you line them up to read the time.
An afternoon later, I had a modified design that closely resembled a snow dome.. how could i resist?
This dial can read to within five minutes of local solar time if you etch the components accurately.
Remove these ads by
Signing Up.
step 1The Maths, yuck.
Don't worry, this will be over soon and there's no exam. Everything vital will be covered when you mark out the plastic.
If you lived a few hundred years ago, you'd know that the earth is flat and the sun goes around the earth. While wrong, it's a good starting point.
The sun passes the roughly same spot in the sky every 24 hours so it spends 12 hours above the base plate. We need to divide the dome into 12 equal increments: one for each hour. This is the equatorial line.
The circle on the base plate is a bit harder to grasp. Every year, the sun wanders north and south, about 24 degrees above and below the equator. As it turns out, this is very close to a sine wave so we'll call upon the unit circle:
The base plate is divided into 12 sections, one for each month. Each month has a height above or below the equatorial line, this height follows the same sine wave the sun follows year after year.
The size of the circle is important too, the sun's rays have to hit the very top or very bottom of the circle at the solstice, making them about 24 degrees north or south of the very top of the dome.
Unfortunately, since this is basically a snow dome, we need to account for the refraction angle into the water.
A bit of mucking about with algebra tells you that the diameter of the circle needs to be about a third the diameter of the dome (0.312 times the size, to be precise).
(If you actually do the algebra, a plot of the sine of the incident angle vs the sine of the refracted light is slightly non linear, but it's only out by less than 1%)
[edit] This is a PDF of some of the algebra.
bubbledial.pdf(595x842) 137 KB|
To Download the PDF or View All Steps, Become a Pro Member » |
You've got the bubble under the dot that marks your latitude (2 degrees of freedom)
You've got the shadow from the line on the dome over a point on the centre line determined by the month. (the other degree of freedom)
Once you've done all that, the dial can only be facing one way (actually two, but one direction will give a time that's on the other side of noon)
When it's lined up, the line on the dome is parallel to the equator of the planet, and the centre line is parallel to the axis of rotation, that gives you true north.
Here in Oz, the southern end of the dial points higher than the northern one so it's easier to be facing true south when you read it.
Really useful stuff but it's a pain when the licences expire every year though.
Brass and leather is always good... look forward to seeing it dolled-up!
If i ever make another attempt, I might try for some metallic trim here and there.
I don't want to get too much into this, but this is why we use watches now a days (and presumably when time traveling) instead of sun dials.
Watches are great for travelling through space, but considering the number of time travel errors that play out in fiction, I'd hate to have to re-set my watch every time I park.
the only other niggling error is the fact that the solstices change over time. However, you'd need to take the Gregorian calendar to the dawn of time for this to be a problem, at which point orbital mechanics are completely different and you need a new dial anyway.
Well, the only thing that could make it better would be a shot of it actually telling the time (with visible shadows and what-not).
Highly creative - well done.
I'll get onto that when the sun comes out.
The line drawing and marking process is slightly confusing, could you post a template of some sort?
(that sounded weird)
Thanks
