3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
sundial, compass, spirit level. All-in-one time piece.
Who wouldn't want to have a wearable sun-dial as part of a time traveller's outfit?
My sister and I always thought a wrist-mounted sun-dial would be completely impractical, Not so.
(although it's still nowhere near as convenient as a normal watch)
To have a functioning sun-dial outside of your garden, you need to know where north is..
Also, you need to keep it level.  How do you combine a shadow, a compass and a spirit-level, and fit it on a wristband?
Researching existing sun-dial designs, one type in particular caught my fancy: the equatorial dial.
It can function at any latitude (if you know what it is) and some of them actually give you true north when you line them up to read the time.
An afternoon later, I had a modified design that closely resembled a snow dome.. how could i resist?
This dial can read to within five minutes of local solar time if you etch the components accurately.
Step 1The Maths, yuck.
Don't worry, this will be over soon and there's no exam.  Everything vital will be covered when you mark out the plastic.
If you lived a few hundred years ago, you'd know that the earth is flat and the sun goes around the earth.  While wrong, it's a good starting point.
The sun passes the roughly same spot in the sky every 24 hours so it spends 12 hours above the base plate.  We need to divide the dome into 12 equal increments: one for each hour.  This is the equatorial line.
The circle on the base plate is a bit harder to grasp.  Every year, the sun wanders north and south, about 24 degrees above and below the equator.  As it turns out, this is very close to a sine wave so we'll call upon the unit circle:
The base plate is divided into 12 sections, one for each month.  Each month has a height above or below the equatorial line, this height follows the same sine wave the sun follows year after year.
The size of the circle is important too, the sun's rays have to hit the very top or very bottom of the circle at the solstice, making them about 24 degrees north or south of the very top of the dome.
Unfortunately, since this is basically a snow dome, we need to account for the refraction angle into the water.
A bit of mucking about with algebra tells you that the diameter of the circle needs to be about a third the diameter of the dome (0.312 times the size, to be precise).
(If you actually do the algebra, a plot of the sine of the incident angle vs the sine of the refracted light is slightly non linear, but it's only out by less than 1%)
[edit] This is a PDF of some of the algebra.
bubbledial.pdf(595x842) 137 KB
34 comments
Jan 8, 2011. 2:47 PMgaiatechnician says:
I made a solar compass too!
It came from my tracking solar cooker and clam shaped solar attempts.
I didn't expect the "2 north's" problem.
It took me completely by surprise!
Is there any way to quickly tell which north is the right one?
If you have a watch you could quickly tell which is which but if you don't it gets a bit harder.
Also, have you considered putting a demo video on the internet?
Survivalists are interested in compass stuff and they should have something much better than sticks in the ground.
Thanks
Brian
Jan 10, 2011. 1:55 AMgaiatechnician says:
Thanks. So basically, morning and evening, it is very accurate, and around noon, you got to be a bit careful, probably need to give it 15 minutes to identify the false reading. Do you know if the ring sundial can work as a compass too or is it strictly a timepiece? (I had a look, there is video too) but I couldn't tell if it works as a compass.
Apr 19, 2010. 2:50 AMmust invent says:
I don't understand...how does it work as a compass?
Apr 22, 2010. 3:17 AMmust invent says:
Thanks.
Apr 5, 2010. 5:52 PMmust invent says:
Do you use Mathematica? And what version?
Apr 6, 2010. 2:48 AMmust invent says:
 I'm using a 15-day trial and I kept replacing the licenses over and over. xD
Jan 25, 2010. 4:41 PMjaredsalzano says:
i always thought that, if a wrist-sundial were to be attached to a compass, it would automatically orient itself north.
Jan 4, 2010. 6:49 PMusb key says:
according to WIKIPEDIA! WOOT WOOT!!!1 the summer solstic is either the 20th or the 21st and the winter solstic is the 21st or 22nd depending on wether or not its a leap year. doesnt really make a difference, just felt like correcting you
Dec 30, 2009. 12:20 AMFred82664 says:
lol Oh man I am late for wok ,,,, My dial did not go off and wake me up lol  but all jokes a side This is cool !  I would do this one trying to make use of those Gum ball toy case things ,,,,,,,Those cases them rings and cheap toys you can get out of gum ball machanes for $0.50 to $0.75 . I call them Short Term  Grand Kid Bribers.
Dec 27, 2009. 4:47 PMwocket says:
I might try this with silver and a floating hollow lens filled with water to make it true steampunk, I'll let you know how i go!
Dec 22, 2009. 11:24 PMJamesRPatrick says:
Wow, I've seen a handheld sundial, but never a wrist mounted one!
Dec 22, 2009. 5:27 PMParapegma says:
 BTW, I forgot to add is that this is the best wrist sundial I've ever seen, bar none.
Dec 21, 2009. 11:42 PMhurtzmyhead says:
I love it! great idea and great execution in the building!
Dec 21, 2009. 5:38 PMParapegma says:
 Depending on your Longitude, solar time and Local time (time in your time zone relative to GMT) can be as much as two hours off. You also have to correct for the equation of time for your latitude/longitude, so there can be quite a difference. In addition, true north and magnetic north vary considerably world wide.
I don't want to get too much into this, but this is why we use watches now a days (and presumably when time traveling) instead of sun dials.
Dec 21, 2009. 9:06 PMParapegma says:
 Unless I misread " making it work," you did not include a correction between zone time and solar time. Perth is pretty close to 115 degrees , so I think your correction is only a few minutes plus or minus for zone time plus equation of time.  You need both that and your equation of time to correct from solar time to zone time (as in time zone) . Equation of time also changes over the years because of changes in the earth's orbit and other factors. Astronomy does not use the Gregorian calendar but instead  uses the Julian calendar in a modified form which enables it to place events anywhere in time / space  from the big bang onward. This includes the solstices. Because change in orbital mechanics  is pretty regular and pretty predictable, you should have no problem figuring them out.
Dec 21, 2009. 10:15 AMKiteman says:
Oh, this is so...
Well, the only thing that could make it better would be a shot of it actually telling the time (with visible shadows and what-not).
Highly creative - well done.
Dec 21, 2009. 5:28 PMmad_scientist says:
 Awesome, I've always wanted a wearable sundial.
The line drawing and marking process is slightly confusing, could you post a template of some sort?
Dec 21, 2009. 10:53 AMOblivitus says:
I had the same idea when I was in Middle School. I didn't have the skills to actually make one then though. Good job.
Dec 21, 2009. 6:18 PMOblivitus says:
Indeed it did, your welcome.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:EGiR(Evil Genius in Residence)
