THIS IS FOR YOU! If you like simple, useful, and easy processes, give this a try. this just takes a few simple steps, and is very easy to do. You need NO experience with tools. If you can stick something with tape, and use a knife, you're set. If you can't... well, there's not much I can say about it, but that now is a good time to learn!
Below is a picture of a stickman and a camp fire. That's they type thing you should get when you're finished! The best thing is, it takes very little to master this technique! Once you get the hang of cutting curves on the tape, the rest is simple!
One KEY advantage to this method VS say a spray paint stencil, is that I can make REUSABLE stencils with ISLANDS. That means that I can do letters WITHOUT having to worry about those annoying "legs" that are needed to create blank spaces in the middle of a figure.
*please note* steps 8-12 are on making a stencil for repeated use of a particular design
Remove these ads by
Signing UpStep 1: Step one: get those materials!
-DARK sunglasses- very important! We prefer to keep our eyes intact. if you've got welding goggles, those'll work too.
-Aluminum foil tape- the shiny stuff, you COULD use aluminum foil, but, it's going to be one heck ova lot harder that way.
-Razor blade- Exacto knives are preferred.
-Magnifying glass- one larger then 3" (~10cm) diameter circle, or rectangular equivalent.
-Material to be engraved- dark objects or wood are best
-A sunny day
*a side note, please try to steer clear of carcinogenic materials, However, if you must burn them, wait for a breeze, and stay upwind of the object, and downwind of other people (or a good ways away from them!) I'd prefer if you just take simple precautions to keep others safe. While probably not a problem, it's a good idea nevertheless. HOWEVER, plain 'ol wood is no problem, and you don't need to worry about that!
Visit Our Store »
Go Pro Today »
With that being said,Happy Solar burning.☺☻
I have an idea to make stencils that might be a little more work and a little more expense but I think the end result would be better. There is a product called Looking Glass. This is a spay "paint" that creates a mirror like finish on glass. By masking off your glass with a paper or vinyl piece in the pattern you wish to burn then spraying the glass with the Looking Glass paint you should end up with a mirror with voids that are in the pattern of the design you wish to engrave. Only experimentation will tell how well it would hold up.
I was just trying to add another idea to this good project.
Now, :) let me add something...
It could be possible to add 3D to the shadows (some less dark shadows) by cutting away some parts of the stencil after half burning the complete silouette...
So, the new cut parts would be half burned while the rest would look as mentioned in this interesting article.
For example, the front log of the first picture, would look less burned, so more close to the observer...
Hurray, I have added something! :)
I'm surprised that no one suggested that you cut the stencil on the glass *in reverse* so that you can then lay the glass onto the wood with the cut pattern on the bottom of the glass, nearest to the wood. That way, you retain the sharp edge that you get when your stencil is in direct contact with the wood. I would think that the sticky side of the tape is still reflective enough to do its job in that mode.
-bp
Also, many glass shops sell cheap glass if you need an unusual size, to say make a 3' long by 8" high engraving in a piece of wood.
We had made about 20 different ones for Reunions, Yard Sales, etc. using a wood burning tool, this might have saved some time. Now we just use a dremel tool with metal templates, but this is a nice cheap way.
Good intsructable. =)
Lo-and-behold, Edmunds is still around and still offers the exact same 11" square Fresnel lens for just $5.95! Shipping starts at $6.75, so you would probably want look around for some other goodies and/or get a friend to go-in with you and get several lenses.
Large Surplus Fresnel
