3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
sunlight engraver! A simple way to engrave!
Step 8Making a stencil for repeated use
Ok, it's been mentioned that it'd be great to have a stencil that could be used over and over and over again. While if the shapes aren't very complex on the piece of tape, you CAN lift the tape off, and re-stick, and re-use, this will won't work too well more then one or two times.
So how do we solve this? We'll build a stencil!
items needed
-razor
-sheet of glass or plastic (glass is VERY MUCH preferred)
-foil tape
-scissors
Panes of glass in small sizes are readily available from scanner tops (on the 4-in-1 printers) and old window panes. If you've got a junkyard local, you might be able to lift some off of them for pretty cheap.
1 comment
Jun 7, 2007. 5:26 PMfortgeorge says:
You can just go to a department/discount stores and buy a picture frame to take the glass out of, pretty cheap and readily available. You can get an 8x10" for about $3-4, larger sizes are $6-12 depending on how big ya get it, provided you don't need like poster size.
Also, many glass shops sell cheap glass if you need an unusual size, to say make a 3' long by 8" high engraving in a piece of wood.
We had made about 20 different ones for Reunions, Yard Sales, etc. using a wood burning tool, this might have saved some time. Now we just use a dremel tool with metal templates, but this is a nice cheap way.
Good intsructable. =)
Aug 4, 2007. 2:40 PMJustAnotherDave says:
I picked up an (eminently discardable) 8x10 frame with (thin but usable) glass at the dollar store.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
54
Author:thecheatscalc
