super cool bicycle LED tail light Fiber Flair glowing glue stick by jim_2000
Featured
The inspiration for this Instructable came from a product a friend purchased for his recumbent bicycle, the Fiber Flare. The Fiber Flare shines two LEDs down a solid tube of plastic and provides a nice glowing indicator. I wanted to see if I could make one from items around the house. I was successful and am proud to introduce this Instructable I call the Fiber Flair!
Step 1: Assemble the materials
Parts list: 9v battery, 9v battery clip, 10 to 1000 ohm resistor, two 3mm LEDs, wire.
Before we get started, lets take a look at the Fibre Flare
If you take a close look at the 2nd picture you will notice the hunk of plastic sort of looks like a glue stick from a hot glue gun. Glue stick? What is an Instructable without a glue stick? What happens when an LED is shined into an actual glue stick? Believe it or not, it actually lights up like a glow stick! What is so cool about this is that the glue stick is a very low cost diffuser. The diffuser spreads the LED light so it is visible 360 degrees.
zazenergy says: Aug 24, 2011. 1:40 PM
Wow, I love the light you're getting off this. Really helpful instructable. How are you going to attach this to the bike? A couple zip ties?
Thanks!
jim_2000 (author) says: Aug 24, 2011. 4:18 PM
I like duct tape. Zip ties fail when exposed to sunlight. I'm also trying to make an inner tube strap for this light.
escapefromyonkers says: Dec 27, 2012. 8:22 PM
There are a lot to Zip ties, like duct tape they are not equal. For bicycle stuff and most stuff I like the . Thomas and Betts 7.3 inch X .184 or 166mm X 4.67 have a tensile strength of 50lbs/220N at a max wire bundle of 1.75 or 44.4mm nylon wearable material with a stainless steel "zip"
there are called TY-Rap and last for years attaching cables on outside telco plant. There are a lot of junk ones out there, even in telco we would get the lowest bidder sometimes,but with proof of their failure, the better ones were stocked . We had some , I think brand name was del-tec that came in 18", 24", 36", and rolls of about 25 feet , that you could cut to custom length., They are about 1/2 inch wide and that are extremely strong and impervious to the elements , we could cut to length and had non corrosive metallic zips,copper colored "zips" that came in separate bags.
if you know a utility guy ,he/she can show you the differece. There are some real small weak ones ,around 5 inches , that come in colors with stripes,, and are used to mark the count of cables,not for any strenth functions.
Find a old telco utility guy with a cherry picker type truck,they know the difference. in ty-wraps
escapefromyonkers says: Dec 27, 2012. 8:29 PM
oh, i forgot to say, very cool light and use of glue sticks, and all the other devices mentioned, have to check out the antifreeze and gelatin too. I have a couple recumbent, want to get a trike , but want some kind of lasers that shoot straight up to keep the cars from running me over.
longwinters says: Dec 27, 2012. 3:08 PM
Nice look I just posted a project with a similar format, I used anti freeze and gelatin to make a glowy core, I assume your LED's are white?
http://www.instructables.com/id/Working-Night-vision-Periscope-Steampunked/step5/The-side-light/
destrianugerah says: Dec 27, 2012. 7:48 AM
cool
Databanks says: Aug 25, 2011. 6:48 AM
Oddly enough the bracelet style glowsticks happen to fit on a 5mm LED just nicely - well, their joiners do, anyway. So, got a few dead glow bracelets left over? Otherwise, identical to your circuit should do nicely. Slide a joiner on each end, LED in the joiners, all done. My kids have a stack of dead sticks, might try colour matching (red LEDS on red glow sticks, etc).
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
