3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
(reference)super simple CNC
Hear are my designs for a CNC. My goal is to make a cnc anyone can build with no special tools except a screwdriver. Please comment on what you think even if its criticism.
Some things i would like to improve are
*The z axis: i feel like it could be similar
*the x axis carriage could be simpler without special bearings
cnc.skp226 KB
10 comments
May 11, 2012. 7:00 AMshortcircuitaz says:
http://www.cnczone.com/forums/open_source_cnc_machine_designs/12681-hardware_store_design_cnc_router.html
these guys are aproximately 80 - 90% done designing one with the same goals
http://www.instructables.com/id/How-to-Make-a-Three-Axis-CNC-Machine-Cheaply-and-/
this one is already an instructable...
http://www.instructables.com/id/The-DIYLILCNC-Open-Source-Plans-For-a-Low-Cost-E/
this one is a bit more complex... but the same idea as well...
Jan 13, 2012. 7:34 AMlrdforster says:
Looks interesting, I am looking at something similar myself.
Apr 17, 2011. 2:49 PMkwy007 says:
I like it!
I hope to see more.
Mar 1, 2011. 3:47 PMPS118 says:
Instead of wood, you might consider going with cheap chain-link fence pipe, electrical conduit, or even gas pipe. It's easily scrounged or fairly cheap from the local hardware store, super rigid, and most of all should slide much, much smoother than wood.
My other idea I want to try (if I ever get around to building one) is to forget about the all-thread lead screw idea and just use a direct friction drive (just a motor with a rubber tire). To close the loop I'd use a optical mouse sensor.
http://www.martijnthe.nl/2009/07/interfacing-an-optical-mouse-sensor-to-your-arduino/
Just some ideas for you to play with. Have fun building! Let us see when you're done! :)
Apr 4, 2011. 8:33 AMkalboon says:
I tried to make a direct friction drive for one of my projects as well, its fairly difficult for several reasons first off is if you have to much load on it the tire will just spin and go no were, like a front drive car with the e-brake locked, secondarily, if your driving it from 2 sides getting them to move exactly enough for precision work is tough, I had limited success, maybe you will have more, just some things to think about =)
Mar 31, 2011. 9:48 AMThefsxmad says:
I love the idea of a CNC machine that anyone can build. But even if you plan on making it from aluminium you will need to add lots of reinforcing, many CNC machines have a maximum definition of 1/100mm, so the frame needs to be as strong as possible, especially if you have a high speed cutter whizzing around inside it. Also, the frame could be considered the easy part, it's the electronics and software which are more complicated and need the thought. Keep working on it, it's a great idea.
Feb 23, 2011. 11:01 PMadamazing says:
The general construction looks a bit flimsy. The width of the wood used for the uprights, side rails and the X-axis(?) guide rail looks far too thin. They look like they would sag under the weight of the drill/tool used or even just the weight of the drive motors/gears. Even a little big of sagging is not what you want when you're trying to do stuff with precision. Or is it not to scale?
Feb 23, 2011. 11:57 PMrickharris says:
Long way to go yet.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:mman1506
I live in Toronto, Canada and I build almost anything computer related, Anything from robots to computer interaction devices. My favorite programming language is C+ and micro controller is avr with t...
more »
