3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
super simple ignition coil drivers
Step 1Lets start with the bacics
lets start with the bacics
OK, an ignition coil (or spark coil) is a type of induction coil similar to a Tesla coil . it's used in combustion engines. and produces up to 50,000 volts (a 4.9 CM spark) at a lethal current of 25ma.
to power it, you need a square wave. you cant use standard AC because the coil WILL EXPLODE ! with absolutely NO output AT ALL .
28 comments
Apr 29, 2012. 5:06 PMR.A.T.M says:
couldnt you use this for a fly back
May 1, 2012. 6:57 PMR.A.T.M says:
okay thanks man
Jan 31, 2012. 1:40 PMfreenergyfuture says:
I can't quite tell which direction the power flows, and where the battery would connect.....
Aug 15, 2011. 11:28 PMbswt says:
relay did not last that long
May 4, 2011. 2:07 AMThe MadScientist says:
Did you actually test the shock I've shocked myself with HV a lot more than I should have but I would never do it intentionally? Camera flash systems really hurt as well as HV capacitor discharge. My worst with ignition coils was a direct strike from this ignition coil driver.
Aug 3, 2011. 1:48 PMspark light says:
Actually, that is not a high voltage muffler so much as it is a gate drive shaping circuit. It limits the current between the 555 and mosfet during turn-on which momentarily takes it into it's linear region. Then, it gives it a hard, quick turnoff, but still protects the 555 from mosfet failure by current limiting.
May 5, 2011. 1:18 AMThe MadScientist says:
That does look pretty high Amp the flash circuit hurts enough.
Aug 5, 2010. 5:48 AMKirbsome! says:
I've been looking for something like this, can the first driver use a 9v battery?
Aug 5, 2010. 1:36 PMKirbsome! says:
So, I need low voltage high amps?
Nov 10, 2010. 6:42 AMGujkil says:
what parts i need for the driver?
Nov 11, 2010. 2:41 PMmigsters says:
Will a OMRON SPST 10 AMP Relay work? If so, how would i go about hooking it up?
Oct 10, 2010. 11:57 PMone8877 says:
how the diagram if I use a motorcycle coil
Aug 24, 2010. 4:16 PMJimmy Proton says:
are you saying you can make an oscillater with a relay?
Aug 25, 2010. 3:35 PMJimmy Proton says:
is there an instrucable on how to make one cuz i didnt c 1
Jul 27, 2010. 3:43 PMrimar2000 says:
Forgive my ignorance, would serve this device to generate ignition sparks at a rate of tens per second? I need something so for an experiment...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:-max-
