Support DIY and Instructables : Become a Pro Member Today!
supercharged lemon
intro
introsupercharged lemon
build a lemon-powered flashlight!
normally it takes 3 lemons to get an LED slightly glowing...
with this design you can make a single-lemon-powered flashlight that will run for weeks!!!
credits:
it was developed during the exhibition "Cooking and Constructing" at Platform21
joule thief design
supercharged lemon
Remove these ads by Signing Up.
To View All Steps on one page,
Go Pro Today!
step 1prepare the components
to make this lemon light up you'll need the following tools and components... tools: - multimeter - soldering iron - steel scissors - pliers - sanding paper - AA battery (for testing) - knife - pen components - lemon - 1 kOhm resistor - NPN transistor - ferrite bead - copper wire - sheets zinc & copper - white / blue LED
step 2wind the transformer
this transformer is the crucial element to make joule thief work with lemon. it requires much more winding then in the normal joule thief design and only plain ferrite works - all colored rings failed. 1. take about 1.5-2 meters of copper wire, bend it in half and wind the coil with it. in this case it took around 50-60 windings arranged in two layers. 2. after the …
step 3prepare the transistor
take the transistor and bend it's legs: the middle one - goes straight backwards the side ones - go forward and a bit more to the sides afterwards - pre-solder all the legs
step 4solder & test the joule thief
now we're going to build the joule thief itself solder the resistor to the middle leg the short leg of the LED (the minus) goes to the rightmost leg of the transistor, and the long (the plus) leg goes to the LEFTmost leg of the transistor the transformer gets one of it's single-wire tips soldered to the loose end of the resistor, and the other single-wire tip goes…
step 5make copper electrodes
1. process copper plates with sanding paper 2. cut pieces that would fit nicely in your lemon 3. pre-solder spots on the electrodes 4. cut a length of copper wire about twice the length of you electrodes combined 5. remove the lacquer from the wire in the same way you did it for the transformer 6. solder the wire to the electrodes 7. check everything is soldered p…
step 6make zinc electrodes
as zinc is not easy solderable, we'll have to use some force here 1. process zinc plates with sanding paper 2. cut pieces approximately the same size as copper ones 3. make small in the top of every piece and bend them 5. prepare the wire in the same way as with copper electrodes 6. clamp the wire with zinc pieces using pliers 7. make the conductivity test
step 7stuff the lemon
here comes the juicy part... 1. to reduce your lemon's internal resistance (thus boosting it's current output) you have to smash the lemon several times and roll it on the table until it's all soft an juicy inside 2. mark 8 cuts with as much space between them as the lemon size allows 3. make the cuts as vertical as you can and to the bottom of the lemon 4. insert…
step 8finalize!
solder the joule thief to the lemon, and you're done! the twisted transformer wire goes to copper electrodes, and the minus leg of the LED - to zinc electrodes. the last photo is the comparison between the freshly made lemon and the one that was running for a whole month by now.
142 comments
1-50 of 142
Apr 5, 2008. 2:00 PMKiteman says:
Nice idea. But does wasting food count as "green"? Would it work as well if you used sea water, or water full of potentially current-carrying pollutants (then you could call it a lamp run on pollution!).
Sep 26, 2009. 10:04 PMgreenbean says:
A lemon can turn into soil and another lemon can grow from it. Pollutants can't, and neither can a battery. This isn't the next oil, as it is not efficient, but it is an interesting and feel good way to run a small clock for a month.
Apr 27, 2008. 11:29 PMJustinger says:
Just a thought about "green". Using something that reproduces like a plant in the process of acquiring energy sounds very "green". No footprint, yada yada. For this contest in general I would imagine that all reoccurring fruit usage is very fair game considering that plants continues to produce while the fruit decays. The only downside I would see is the good one could do with food for the needy, although I don't imagine starving people would prefer a box of lemons.
Apr 28, 2008. 1:10 PMKiteman says:
Something to add to the thought, though, is the energy required to process the lemon - pick, pack, transport. If it came from your own grove, I'm sure it would be C-neutral, but all UK lemons come from overseas.
Jan 27, 2010. 1:23 PMknektek says:
use the seeds in the lemon to plant. now that would complete the life cycle.
Jun 30, 2009. 10:47 AMLogan M. says:
I grow my own lemons (wow that sounded weird lol)
Jul 15, 2009. 12:27 PMRedgerr says:
it really did lol
Apr 5, 2008. 6:28 PMMr. Rig It says:
Hmmm... we could look at it from a different perspective. How is it "wasting" if he is consuming the energy from it? When he is done he can compost it etc ect. If he didn't live near sea water he would have to make his own, would that be "wasting"? Just personal perspective questions.
Apr 6, 2008. 3:38 AMKiteman says:
I was half thinking, without checking the practicality of it, if this could be used to clean water polluted with metallic ions - the polluted water flowing between the electrodes (in place of the lemon), and instead of the LED, a pair of plates downstream of the electrodes, gathering metals by electrolysis.
It would pretty much be a self-powering pollution-clearing device.
Sep 26, 2009. 10:09 PMgreenbean says:
metal ions are not pollutants. They are what make the water conduct electricity and without them we can't drink it. The distilled water is abrasive and sucks out things from your body so that it is not distilled. Water always wants to have something in it.
Sep 27, 2009. 2:33 AMKiteman says:
As I am sure you are aware, there is more than one kind of metal. Water containing small traces of calcium will be fine, but high levels of lead, mercury, tin, copper, uranium, iron, in fact just about any metal will always make water toxic.
Sep 28, 2009. 1:13 PMgreenbean says:
The issue is that it takes out ALL the ions, making it distilled and therefore undrinkable.
Sep 28, 2009. 1:36 PMKiteman says:
Oh, sorry, I wasn't disputing that DI was not a clever drink - I thought you were saying that water needed plenty of metallic ions to be healthy. (You can drink DI for short periods, although it is utterly tasteless. I was bored before the end of my first glass.)
Sep 27, 2009. 5:49 AMKryptonite says:
Would that be like just consuming finely shaved (insert deadly metal of choice)?
Sep 27, 2009. 6:04 AMKiteman says:
No - most toxic metals are toxic as compounds, which is why things like lead have been banned from petrol and paint.
Mercury, though, is toxic as the metal as well (do you know why the Hatter is Mad?)
Sep 27, 2009. 5:40 PMKryptonite says:
Well I do know a bit about mercury; one day i'd like to get a radiation suit, fill a silo with mercury and use it as a trampoline. And the Hatter? Has he been playing with thermometers?
Sep 28, 2009. 2:49 PMgreenbean says:
That would be fun!
Sep 29, 2009. 2:19 AMKryptonite says:
Although half a tonne of mercury isn't going to go down with the local council very well... XD
Sep 28, 2009. 5:52 AMKiteman says:
Hatters used felt, felt was made with mercury, mercury fumes damage the brain.
Sep 29, 2009. 2:17 AMKryptonite says:
I guess one does learn something every day!
Sep 27, 2009. 5:35 PMgreenbean says:
Actually many elemental metals are toxic. Iron is necessary for humans, by the way.
Iron is necessary, excess iron is dangerous.
Sep 29, 2009. 2:16 AMKryptonite says:
How about that dude that ate a plane?
Sep 29, 2009. 8:53 AMKiteman says:
He ate metallic metal (and an awful lot of plastic, card and glass) - it's mainly metal compounds that are the toxic beasties.
Oct 1, 2009. 2:52 AMKryptonite says:
Ahh I see, so next time I go for a midnight snack I should definitely check the ingredient list of my Boeing 737.
Apr 6, 2008. 3:22 PMpyro13 says:
That would be cool, i would like to see it done, but wouldn't that be a machine that ran for infinite, and my science teacher claims we cannont make something like that, so i would like to see it done! =D
Jun 8, 2008. 11:31 PMGrey_Wolfe says:
This isn't a perpetual motion device. It could run indefinately as long as a xcontinuos source of poluted water was there to power it. It would of course need cleaning from time to time do to build up of said pollutants. And maintainance for basic wear or corrosion. But the device has an 'outside' power source in the water.
Apr 7, 2008. 1:50 AMKiteman says:
It's not over-unity (I think) - it would be using the chemical energy of the pollutants themselves, refreshed by the kinetic energy of the flowing water.
Apr 12, 2008. 7:28 PMtriggernum5 says:
You wouldn't be able to clean it thoroughly really.. You'd hit an equilibrium where metal ions formed neutral compounds in solution.. To prevent that kind of action membranes need to be engineered to particular expected anions and cations.. I wish it was that easy though.. If it was I could get pure sodium and potassium metal from simple aqueous electrolysis..
Apr 7, 2008. 1:53 AMKiteman says:
If I'm right (and I may not be), it would extract the metals (often the most toxic part of a pollutant) as solids on the electrodes.
Oh...
But the other electrode will simultaneously corrode, replacing the polluting metal with a different polluting metal.
Bum - that's a dead idea.
Jun 8, 2008. 11:38 PMGrey_Wolfe says:
It was worth a try. Perhaps a physical filter could be placed around the corroding electrode. Fine enough to allow water to pass, but not permit contamination back into the main body of water. Would provide for a bit more cleaning upkeep, but it might work. assuming the your new contaminant are larger than water.
Apr 6, 2008. 12:11 PMduck-lemon says:
yeah that would be cool
Apr 5, 2008. 6:08 PMCameronSS says:
Well, it doubles as a citrus air freshener, so that should count for something.
This is a clever idea! It would have fit in the Mash-Up contest, too.
Apr 5, 2008. 5:03 PMkillerjackalope says:
Ah but the food was made using Co2 removing methods so it's fairly green either way, that and I'm pretty sure that you could use a different media such as polluted water made from condensing the suphuric acid etc. made in coal power stations in water, I think that would work, I can't quite remember how it works due to my own poison... Masybe tomorrow, in fact make that the next day...
Apr 5, 2008. 5:03 PMPKM says:
I'd like to know whether using a lemon is more or less green than disposable alkaline batteries- someone should do a complete environmental audit (energy used, CO2 production, transportation, waste product disposal etc), and I think that would make a great science fair/research project. If I had kids, I'd set them straight on it :) Personally I'm not sure the lemon is the major materials expense- surely refining the copper/zinc counts as well, as they are consumed in using the battery, and copper prices are at an all-time high. Another random tangent- this is a fairly well known experiment, but are there any vaguely practical (read- can power this sort of project, not necessarily laptops or a Prius) rechargeable batteries that can be made out of household materials? I'd imagine trying to charge this would just make your room smell of burnt lemon...
Sep 26, 2009. 10:14 PMgreenbean says:
Yes, but you can continue to reuse the copper and the zinc. All you replace is the lemon. Even with transportation, lemons grow on trees. That turns CO2 into O2, which is good. Alkaline batteries have pollutants and harmful materials in them while lemons make good compost to grow more lemons.
Jul 15, 2009. 5:29 PMLogan M. says:
Hmm...Burnt lemon...I wonder what that would smell like (Lights the grill with a lemon in one hand. Mwahahaha.)
Apr 7, 2008. 2:40 PMleemik says:
If you had something that did not use a lot of power you would would want to use lemons. the opposite if you were using something that used a lot of power.
Apr 5, 2008. 6:00 PMkillerjackalope says:
Hmm worth a go, a car battery works on a similar priniciple.. then again household products could be used and reacted ad infinitum to make the base materials...
Jul 19, 2009. 12:16 PMsolarmatrix says:
great instructable s8, i built this lemon Battery with a slightly different circuit it worked well. lit up my digital thermometer & used as a night light. Thumbs up mate!
demon lemons strike again O_o i see in the last picture they are pretty dead by the time the energy is used up eh?
Oct 28, 2008. 2:39 PMthatmantheuser says:
What was the purpose of the transistor?
Nov 22, 2008. 2:13 PMjunits15 says:
a joule thief works by making thousands flashes perseccond, thus the need for a swithc of somesort,in this case it it the transistor, but a solid state realy might work too
Feb 21, 2009. 12:20 PMReCreate says:
oh so the light flickers? how fast 10hz? or what?
Feb 22, 2009. 4:40 PMjunits15 says:
it flickers faster than AC current, and that is 60Hz
Feb 22, 2009. 8:07 PMReCreate says:
so about 100 something hertz? wow you would probably need a high-speed camera to capture that flickering
Mar 14, 2009. 9:24 PMfrollard says:
its probably way too fast for all but the highest end cameras
Mar 14, 2009. 10:49 PMReCreate says:
no...ive seen cameras that record at up to 5000 frames per second you would need a 60 FPS camera to record it according to s8 since he says that they flicker at 40-50 hertz that 40-50 times per second ...right?
1-50 of 142
Related
