normally it takes 3 lemons to get an LED slightly glowing...
with this design you can make a single-lemon-powered flashlight that will run for weeks!!!
credits:
it was developed during the exhibition "Cooking and Constructing" at Platform21
joule thief design
Remove these ads by
Signing UpStep 1Prepare the components
tools:
- multimeter
- soldering iron
- steel scissors
- pliers
- sanding paper
- AA battery (for testing)
- knife
- pen
components
- lemon
- 1 kOhm resistor
- NPN transistor
- ferrite bead
- copper wire
- sheets zinc & copper
- white / blue LED
Could this be powered by salt water ? or even urine?
Thanks,
Pipper Tinker
Following your instructable, my first joule thief didn't work. It does light the led with a 3 volt battery, just not a 1.5. It is a 3 volt led.
Some questions, what kind of 1kohm resistor? The one I bought is 1/4 watt since that's all radio shack had. The transistor was a "general purpose" one. The toroid was large, but uncoated. The wire was 9 feet of 20 gauge.
Does this look right?
Rosie
I'm thinking that the bare wire is to blame, so I ordered 26 gauge enamel coated wire (30 seemed really puny). You mentioned you used bare wire but you had to sand off the coating before soldering so I think you are using coated wire?
Now Im racing the clock before the science fair...
Rosie
the - side of the battery goes to the emitter
the + side goes to the center tab
the led goes to the emiter and colecter (check polarity)
the center tab of the transister goes to the resistor which goes to tone end of the coil
and the other end of the coil goes to the colector on the transistor
as far as i remember now - it was quite tricky to get the transformer winding right. particular ring material would work slightly different with particular wire.
i suggest you to try to approach your particular coil as systematic as you can. make first 10 windings, then 20, then 30 and so on - this will be time-consuming but the most certain way to get it running.
good luck!!!
