Remove these ads by
Signing UpStep 1Materials
12- 2inch abs end caps ( if you want to make 6 mines)
A few feet of 1/4inch surgical tubing (hardware store, need about a foot per mine)
Some thin sheet metal or plastic
1/2inch pvc pipe (only need an inch per mine)
2inch cotter pins and key rings(enough for how many you make)
Epoxy
Wood to make a 1inch tall x1inch wide x1inch long 45degree angle wedge (1 per mine)
Some tent stakes (1 per mine)
Large hose clamps (to go around the 2inch pipe and the tent stake)
Small zip ties
Gasket seal
1: it holds the tubing at an angle so the fluid as a 45 degree path instead of a vertical or horizantal path.
2: it is part of the safety and trigger system. The aluminum parts that ar on the side of the wood block hold the tubing and trigger straight when the trip wire is pulled and they also have a hole drilled for a cotter pin to keep the trigger from being accidentally pulled off. You can make this however you see fit. This is just how I did it.
couldn't have explained it better my self! It works pretty well. It only shoots in a narrow stream so it's accuracy could be better but if it hits they will definitely be marked. I wish I could find a nozzle that will spray in a fan pattern like my other mine.
Actually i'll try it but now i'm thinking it'll require too much force to remove where are this system hold little to no pressure behind that cap.
