Introduction: Telescopic Tazer
iv just moved house and i had an old t.v. arial lying around that i wanted to "recycle"
i also had some corks from another project im working on, and a few sparkers from electric lighters...
the result is an extendable rod that gives a small shock
Step 1: Tools and Materials
you will need.....
Materials:
2x wine corks (i used plastic to save the environent but real would work)
indoor t.v. arial removed from housing/or other extendable metal rod
shocker from electric lighter
Tools:
hacksaw
superglue
hobby knife
*it wont let me do image notes on this pic but its fairly self-explanatory
Step 2: Prepare the Arial and "drill" the Cork
to prepare the arial you just have to cut off the end with a hacsaw or anything you have. not a very clear pic sorry but you just cut off the big chunky part at the bottom to give a hollow tube.
when you have cut off the end, extend the arial, and push it into the first cork halfway up and twist. keep twisting and pushing untill you get it straight through the other side. this will give you a clean hole through the cork.
to remove the core from the arial just collapse it again, but save watever comes out!
Step 3: Main Handle and Button
this is the hardest step to do and its also hard to explain, but basicaly you need to make a hole in the top of the cork big enough to house half the shocker
to do this i used the arial to drill another hole this time only goin through down to the previouse hole, then widened it with the hobby knife.
before pushing the shocker into the hole bend the wire down backwards so its over the battery area, as you push it in (battery first) use a paperclip to grab the wire through the first hole.
*still having problems adding notes -
1st pic - shows top view of cork with shocker inside
2nd pic - shows bent paperclip used to pull wire through
3rd pic - shows shocker with wire bent down towards battery
4th pic - shows finished product looking fairly neat
Step 4: Assemble Tazer Version 1
bend the wire up slightly so that it will make contact with inside of arial. then push arial into the cork (it will only go halfway in because of the shocker.
this was my original design and how i first planned to keep it. however, when i fully extended the ariel i realised it was to har to control with the one cork handle so i added a second one....
Step 5: Version 2.0
as i said, to improve the controll of the tazer i addded a second handle....TOMMY GUN STYLEE (sort of)
to do this cut a small notch in the top of the second cork, make sure part of the arial will fit into it (i put mine at the end of the second section)
then put some superglue into it followed by the arial, and more glue on top to keep it secure.
Step 6: Finishing Touches
remember the cor of the cork you drilled out and kept? now just cut it in half and put it into the open end of the first hole to seal it up... in the pic you can see a small line where the hole has been filled
et voila! finished
just click the button at the top of the main handle and touch someone with the end of the arial to shosk them, remember the longer the arial is extended the weaker the shock will be because of the resistance.
The Instructables Book Contest
