The Axe of Prometheus
2,855
41
6
Published
Introduction: The Axe of Prometheus
choose something you want to copy
Step 1: The Base
because it doesn't exist in real or plan of it, with lots of picture from the movies by second by second to choose the better views and angle you can find
Step 2: Here We Can Real Begin
two years i did a plan but it was a lot less nice...
them two, view from the side and view from under took me nearly 4 hours, and thanks from the maths i did at school wich i needed to do lot of ratio.
Step 3: The Form Appears
i choose to do it at first in clay cause it easy to shape.
after i mold it with reverse alginate wich i love to used, you melt it and you can make a new mold!
you remove the clay and be ready for the plaster
Step 4: Here the Form
i had to do it in two pieces to make easier to shape at first, but, because the blade of the axe is thin non more than 5millimeters it broke :-(
i glued then together and after correct the shape with automobile mastic.
Step 5: My Prefer's Part!!
make the mold in sand in two piece again
and make the aliminium melt!!!
i wanted to do it in iron but the furnace cost a lot more to do so i choose aluminium, that was my first furnace and melt.
Step 6: A Bit of Work Later
an hour later, the axe is ready, corrected and paint with a primer
Step 7: The Handle
again 2 hours of making the plan from the picture
a piece of wood, and carving it.
because it not an axe wich can exist at begining, cause the wood handle should go inside a hole of the blade, this one is not made like this, and looking closer on picture we can see tjat the axe in the movies as a link all along the handle, should be made with two pieces of platic!
i wanted to weld a piece of alumium to make the fixation buti didn't have what's needed so i dril and tap to put a long screw inside which i insert and glued inside the handle
Step 8: Tadaaaaa
glued, painted,
i am happy of the end, pretty good looking, feels strong
looking closer there is some difference with the original even if i wanted to do a perfect copy.
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    6 Discussions
    super cool.. I aspire to work with metal some day soon. also what a fantastic prop.. im sure it would be an effective zombie killing weapon
    I love Nooni Rapace! I loved to watch her in the movie Prometheus and the original trilogy of The Girl With The Dragon Tattoo.
    yes! she have so much charm
    nchey
    3 years ago
    thanks
    i could do a instrucrable for my foundry but i looked other tutoriel even me :-)
    i took a galvanized iron paper and i made the two cylinder, i welded them, plus the handles.
    i take a ciment which can resist at 900°C ,am french :-p
    an card cylinder for the hollow cylinder inside.
    a iron tube and a hair dryer.
    i bought the furnace on aliexpress, alumine ceramic cause i wanted to melt iron, so for aluminium its perfect :-)
    that's great, well done
    That turned out looking amazing! I'd love to see a writeup on your foundry.
