3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
the best ignition coil driver
  • last photo ←
today I'm going to show you how to make (in my opinion) the best ignition coil driver ever! it doesn't need any special electronic parts, it doesn't need a special power supply like 12 volts 4 amps, and it works with the push of a button(moddable)! This is going to be entered into the halloween contest. you can make a miniature electric chair for barbie girl or Lego man! please rate high and leave lots of comments!
Step 1Parts you'll need
parts you\
1) An ignition coil from a car.
2) Some kind of momentary switch rated at least 110 volts, .1 amps. I got mine from a microwave oven.
3) A disposable camera any one that puts out 300 volts will work.
4) A 1 uf 2000 volt capacitor from a microwave oven.
5) some wires with spade connectors also from the microwave oven.
6) Optional: An SPST rocker switch, I got mine from an old computer power supply.
7) A 2AA battery holder from radio shack.
8) A battery clip to fit your holder(no need if yours comes with wires).
See? no special parts! ;-)
31 comments
Jan 18, 2011. 12:44 PMaquadog90 says:
also what gain has got you ignition coil? how many turn on primary and secondary cheers
Aug 7, 2011. 4:11 AMConnorY71 says:
I googled the number of windings and I found it should be in a ratio of 1:100 for primary to secondary.
Jan 18, 2011. 12:43 PMaquadog90 says:
hi what camera make did you use for this project? I am looking at kodak cameras.
Aug 23, 2010. 9:27 PMJimmy Proton says:
where is the coil in a car
Sep 23, 2010. 5:16 PMJimmy Proton says:
actually i did go to the junk yard, very few cars have engines with coils in them but i found one and took it and i could get it to work so i destroyed it and it had a lot of copper in it.
Aug 1, 2010. 7:22 PMisetmyselfonfirefollowinginstructables says:
also, what exactly is a flash charger? i understand you get it from a camera but is it the entire board or just a specific component because yours appears to be covered in tape? or paper? please help!!!!! i really wanna make this :)
Sep 15, 2010. 10:39 PMARJOON says:
it is the board entirely. IT is just that there are 4 wires soldered to it. 2 for battery input and the other 2 for capacitor output
Jun 19, 2010. 10:24 PMNitrato says:
Thank you for sharing that great instructable. I actually was under the impression that the device would work continuously, but after looking the circuit with attention I realized that this isnt a "real" driver, e.g. it can make the ignition coil work but only at the moment of capacitor discharge. I was wondering if l can connect the ignition coil/cap directly to AC part of circuit (the final voltage of that circuit is a >300V DC that feed the photoflash capacitor), but I guess that the current is far too low to work.. So discharging the caps is a much better way... Anyway, great instructable.. Thank you!
Aug 2, 2010. 1:10 PMisetmyselfonfirefollowinginstructables says:
would this one work? 4.7uF 450V HIGH VOLTAGE CAPACITOR or is this one better? 1.05 uF 2100V?
Jul 31, 2010. 7:36 AMisetmyselfonfirefollowinginstructables says:
hey lasermaster, if found a capacitor (finally :P) and it has this written on it... 1.05 uf 2100V would it be sufficient? or do i need to keep looking? thanks for the help.... :)
Jun 19, 2010. 10:49 PMNitrato says:
Just to show, I made a video some hours ago and is there:http://www.youtube.com/watch?v=JKQurku6MQ4 I didnt edited anything in the video yet (even the title).. All the credit goes to this instructable.
Feb 5, 2010. 1:17 PMNicola Tesla says:
can u use a capacitor from a old tv or crt?
Feb 23, 2010. 7:38 PMNicola Tesla says:
the numbers/letters are; 364j  dh
                                             250 sa v
Mar 15, 2010. 11:22 AMNicola Tesla says:
what about this?
Mar 4, 2010. 6:45 PMisetmyselfonfirefollowinginstructables says:
where could i get one of these capacitators? could i perhaps buy one becaus ei don't have any broken microwaves or tv's sitting around :(                                       any ideas? please help...
Oct 25, 2009. 5:27 PMcammel8 says:
Is this merely for entertainment purposes only or is there a practical use for this?  Not that it wouldn't be fun.  Just wonder if there is something that this could be used for like an igniter for exhaust flame shooter or something.
Dec 23, 2009. 6:41 PMmr. clean says:
to make it smaller aside from the capicitor use a coil from a dirt bike
Jan 19, 2010. 7:02 PMmr. clean says:
your welcome glad i could help :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:lasermaster3531
