Introduction: The Desert Buzzard Knex Gun
this gun is a slide top powerful true trigger gun!!! with what I think is a new handle!!! I think you made a good choice if you are building
Step 1: The Handle
1.make thees!
2.then continue making them until its to the desired
size ,try not to make it full it is very hard to get them off,
if the handle must be longer use gray rods
3.make the bottom of the handle
4.then flip it over and make another one
5.push thees in to make it stronger and more comfortable
Step 2: The Ram Construction
1.make thees the letters show witch parts I am talking about later
2.take A and B and connect them together
it is kinda hard but it makes it rely strong
3.take C and A,B together and connect them as shown
4.a substitute picture for 3
5.a substitute picture for 3
6.connect D as shone
Step 3: The Slider
1. make this
2. then this
3.connect them both
4.
Step 4: Trigger
1. make these
2. put 1,2 and 3 together
3. put the 3 4s on
Step 5: Barrel
1.make this
2.bullet lock
3.using a broken one
4.what you do without a broken one
Step 6: The Holder
1.build this
2.different view
3. flipped over
Step 7: Put It All Together
1.so you have thees parts built
2.take B and F and connect them as shone.
3.closer pic
4.take what you have built and C put them in this position
5.front connection
6.back connection
7.put E the handle on
8.helps to see how handle is connected handle
9.take D and slide it into the holes in the gray connectors
10.another view
11.put the A ram in that hole
12.rubber bands for the ram and trigger
The Instructables Book Contest
