Remove these ads by
Signing UpStep 1Step one, what you will need
1. Altoids tin, $2.69
2. a cheap infrared Laser pointer from Walmart, should have a flash light built in $3-$4
3. a Minty boost kit from ADAFRUIT industries, or the the Maker Shed for $19.99 w/o shipping
4. 2 AAA battery holders, that hold two AAA each, at radioshack for $.99
5. a Paint testing/ stirring stick, or tiny piece of wood
6. a High frequency Infrared 5mm Led should look kinda dark blue, used in most remotes. $3.49
7. Hot Glue and a Hot Glue Gun about $15
8. Cheap Soldering Iron Radioshack for $8.99 comes with solder
9. 60/40 rosin core solder, should be included with the soldering Iron $6.99
10. electrical tape pick your color! $3.99
11. Led assortment pack, the best value for your buck, all different sizes, and colors for just $2.99
12. a switch I used a SPST Submini Toggle Switch from radioshack for $2.99
13. 22 gauge solid core copper hookup wire from radioshack $9.99
14. 4 AAA batteries I used recharge able at Walmart $6.99
15. a premade Tv remote jammer, I got one through selling magazines at my school for free, but you could also use a TV BGone from the makershed or ADAFRUIT Industies for $19.99 w/o shipping
16. a Drill, bits, the sizes are 4mm, and 3mm and for the switch, it depnds on what you use, but for mine, a 7mm.
17. side snips, and plyers, good for everything! and a nail...
18. Sigle sided foam tape
19. a dremel tool, quite expensive... you might want to see if any of your neighbors have one you could use, or have them use for you, and make sure it has a small grinding/cutting disc.
15
comments
Add Comment
amakerguy
says:
Add Comment
