3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
the iTIN
Step 3Ready the flash light
This part is actually the hardest part... First take out the batteries , then you need to take your dremel tool, and cut the laser pointer in half. the put the remaining half with the laser, and flash light, and put it in a vice, Not to tight, it is only aluminum, so it's very easy to crush. Then take your pliers, and clamp them onto the top, where you see your laser come out of, a little ways down, there is a seam, this is glued, so if you grip hard and bend it back and forth, it will come out. Then take the circuit board out and desolder the two push button switches, and save them, also take out the little rubber covers, which you see on the outside, and push on to turn on the light. there should have been a heavy duty thick aluminum holder in the cap, take this out and pull out the transparent 3mm LED, and solder another 5 wire from the white prong on the led(prong with white rubber insulator) and take it and solder it on a prong on one of the pushbutton switches you saved from the laser pointer. then on the other prong on the same side on the button switch the right or left prong depending on what side you soldered the other wire on, solder a 4 wire from there to the middle prong of the switch you used for the tv jammer. then take a 3 wire from the prong with yellow casing and and solder it to the ground on the tv jammers circuit. You're
now done!
After I made this, I changed the flash light LED to Two 5mm Blue Super bright Leds, because I've found that they are of coarse brighter, and that the 5mm ones are brighter than 3mm and also because I find that "blue" light is brighter than "White" light, but be prepared to pay $5-$7 each for these 5mm super bright blue LEDs. To do this, just take your wire from the positive of your origional LED and solder on two wires branching off one to the right and one to the left. Then solder on another wire from the negative(bottom) hole on your tv jammer, and solder the ends onto the LEDs, + to cathode(Longer Wire) and - to anode(shorter wire). then drill another 3-4 mm hole on the opposite side of your IR Led, so you have a flash light LED on the left and right of the IR LED. use some hot glue to keep the wires and LEDs in place and you'r done with the lid, so now just take your side snips, and make another cut so and bend it down out of the way, so that all of your LEDs fit and the lid closes nicely. And your done!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:rockandjay
I enjoy making things, the instructables site is my homepage, and every day when I wake up, I search instructables for 3 hours looking for things to spend my day making! I ALSO HAVE A GAIA account Roc...
more »
