3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
the iTIN
Step 5Preparing the tin
Preparing the tin
okay, so now take your drill, and drill a 3-4mm hold in the middle of the lid on the tin on the shorter side of the tin lid. Then take your TV Jammer and place a bead of hot glue on the back of it, and put the led right up to the hole, it should not go through very far, and stick it down on the inside of the lid. Then on the side of the tin with the hinges drill a hole about 5mm wide for your switch, Make sure it's about 1 from the end, to leave room for your minty boost. Then after that, put your red led's hole right next to your switch. and on the back, cut out an area for the usb port, about 1 from the left and cut a little wider than the usb port is, and go slightly down farther than the height of the usb port. Then right next to the infrared LED, drill a 2mm hole for your flash light's LED, and below them, make a notch about half an inch wide, and a 1/4 down from the rim of the box. Okay now make a 5-6 mm hole about 2/4-3/4 of an inch from your red LED.Sweet, you're almost done, no all you have to do is put in the electronics.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:rockandjay
I enjoy making things, the instructables site is my homepage, and every day when I wake up, I search instructables for 3 hours looking for things to spend my day making! I ALSO HAVE A GAIA account Roc...
more »
