3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
the iTIN
Step 6Adding the electronics
Okay, so you should have already added your tv jammer, so now put your switch through it's hole remove, the nut, and the washer, and stick the switch through the hole from the inside out, and add the washer and nut on the out side of the tin and tighten until it doesn't swivel around anymore., then stick your red 3mm led all the way through its hole by the switch, and use some hot glue to keep it in place. Then, take your flash lights 3mm LED and put it through it's hole, it shouldn't go through all the way, and use hot glue to hold it in place. Okay so now to the right of your tv jammer, there should be some room left, and cover all of the room that's left with electrical tape, put on about 4-5 layers, trust me you'll need it...then put in the the rubber button cover you saved from the laser pointer, and cut in half, so you have two separate rubber buttons, and stick one through it's hole. then put the pushbutton switch right behind it, push on it until it almost clicks and turns on but not quite and hold with two fingers, and excessively use hot glue to hold in place. Then hot glue in the battery holders, one going vertically, squished as far as it will go to the left of the tin, and use hot glue on the bottom of the holder, and push down back into place, and one, going sideways,(horizontal) pushed over to the left as far as it will go, it should touch the other holders side and hot glue the bottom like the last one. Okay, now use your single sided foam tape, and stick on the bottom and sides, of the right of the tin, then push your minty boost into place, it will be a tight fit, but I managed to do it, so you can too., then hot glue in the usb port as good as you can. okay this is the final step, take your paint stirring stick, and it in half in the middle of the stick, and cut out two 1" pieces from the stick, and hot glue together. then stick between the push button switch, it should put pressure on it, and the other end should touch the horizontal battery holder's side, and hot glue into place. If you did it right, everything should fit, and the pushbutton switch, should now click when pressed.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:rockandjay
I enjoy making things, the instructables site is my homepage, and every day when I wake up, I search instructables for 3 hours looking for things to spend my day making! I ALSO HAVE A GAIA account Roc...
more »
